HPE ProLiant ML30 Gen10 Intel Xeon E-2134 16GB
Quicklinx: F7NVWS00 Mfr#: P06789-425
Case Style: Tower
Processor Type: Xeon
Hard Disk Capacity: 0GB
Processor Speed: 3.5GHz
Installed Memory: 16GB
  • Xeon
£713.47 ex VAT
£856.16 inc VAT
Do you know that a reliable enterprise-class server can easily meet your budget? The HPE ProLiant ML30 Gen10 server is a powerful yet affordable tower server designed for small offices, remote and branch offices to run on-premise and Hybrid Cloud solutions, delivering enterprise-class performance, security, reliability, and expandability at a lower cost. Just a small change can give you an extra edge. Hewlett Packard Enterprise builds security right into the server with HPE iLO silicon root of trust, making the HPE ProLiant ML30 Gen10 server one of the world's most secure industry-standard servers. Redundant power supply option and hot-plug HDDs provide availability and flexibility. The enhanced expansion capability allows you to upgrade with SAS controllers, networking cards, or graphics cards as your business grows. You will be surprised at how much benefit you can get with HPE ProLiant ML30 Gen10 server.
  • Powerful yet affordable server for your daily office workloads
    The HPE ProLiant ML30 Gen10 server, powered by Intel Xeon processor and 2666 MT/s DDR4 ECC UDIMM, delivers abundant performance for small- to mid-sized business applications. Big storage capacity makes HPE ProLiant ML30 Gen10 server an ideal data storage solution for your business to cope with the increasing amount of data. The option of a dedicated HPE iLO port allows you to dedicate more bandwidth to network functions to achieve higher network performance. The embedded SATA HPE Smart Array S100i Controller ships standard and the redesigned HPE Smart Array Controllers allow you the flexibility to choose the 12 Gbps controller that is most suited to your environment.
  • Variety of enterprise-class features to achieve business growth with lower TCO
    The HPE ProLiant ML30 Gen10 server offers flexibility in different storage needs. Error-Correcting Code (ECC) memory protects business from data loss and unplanned system downtime. The HPE ProLiant ML30 Gen10 server offers a complete set of embedded HPE Integrated Lights Out (iLO 5) for Gen10 Servers management features, which includes HPE iLO with Agentless Management, Active Health System, and intelligent provisioning.
  • Security innovations
    The HPE ProLiant ML30 Gen10 server is one of the Hewlett Packard Enterprise industry-standard servers with major firmware anchored directly into the silicon security protection built-in across the server lifecycle, starting with silicon root of trust. Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware. Secure recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.
HPE ProLiant ML30 Gen10 Performance - tower - Xeon E-2134 3.5 GHz - 16 GB
Server - tower
Height (Rack Units)
4U
Region: United Kingdom, Europe
Server Scalability
1-way
1 x Intel Xeon E-2134 / 3.5 GHz (4.5 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) DDR4 SDRAM - ECC - PC4-21333
Storage Controller
RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software RAID)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE
17.5 cm x 47.5 cm x 36.83 cm
10.1 kg
Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Server
Product Form Factor
Tower - 4U
Server Scalability
1-way
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
4.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C246
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Interfaces
VGA
Interface (Bus) Type
PCI Express x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC332i
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 2 (total) / 2 (free) x M.2 Card
1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 6 x USB 3.0 (1 front, 4 rear, 1 internal) , 1 x USB 2.0 (1 in front)
System fan, PCI Express riser card with fan
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EMC, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1, UEFI
Power supply
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
500 Watt
17.5 cm
47.5 cm
36.83 cm
10.1 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
23 dBA
Case Style: Tower
Brand: HPE
Price Range Ex VAT: 500 - 750
