Do you know that a reliable enterprise-class server can easily meet your budget? The HPE ProLiant ML30 Gen10 server is a powerful yet affordable tower server designed for small offices, remote and branch offices to run on-premise and Hybrid Cloud solutions, delivering enterprise-class performance, security, reliability, and expandability at a lower cost. Just a small change can give you an extra edge. Hewlett Packard Enterprise builds security right into the server with HPE iLO silicon root of trust, making the HPE ProLiant ML30 Gen10 server one of the world's most secure industry-standard servers. Redundant power supply option and hot-plug HDDs provide availability and flexibility. The enhanced expansion capability allows you to upgrade with SAS controllers, networking cards, or graphics cards as your business grows. You will be surprised at how much benefit you can get with HPE ProLiant ML30 Gen10 server.
Powerful Yet Affordable Server for Your Daily Office Workloads
The HPE ProLiant ML30 Gen10 server, powered by up to 6 cores in the Intel Xeon E Processor and up to 64 GB of 2666 MT/s DDR4 ECC UDIMM, delivers abundant performance for small- to mid-sized business applications.Up to 61.44 TB storage capacity makes HPE ProLiant ML30 Gen10 server an ideal data storage solution for your business to cope with the increasing amount of data. Onboard M.2 slot with NVMe SSD support delivers outstanding speed for boot drive.The option of a dedicated HPE iLO port allows you to dedicate more bandwidth to network functions to achieve higher network performance.The embedded SATA HPE Smart Array S100i Controller ships standard and the redesigned HPE Smart Array Controllers allow you the flexibility to choose the 12 Gbps controller that is most suited to your environment.With selection of Hewlett Packard Enterprise qualified professional 3D graphics cards, HPE ProLiant ML30 Gen10 server can easily handle graphical workloads such as medium size CAD models, basic digital content creation, and medical imaging. -
Variety of Enterprise-class Features to Achieve Business Growth with Lower TCO
The HPE ProLiant ML30 Gen10 server offers flexibility in different storage needs. With the choice of four Large Form Factor (LFF) non-hot-plug, hot-plug, or eight Small Form Factor (SFF) hot-plug drive options, you can find the right storage fit for your growing business.The selective HPE 500W Flex Slot Platinum Hot Plug Power Supply Kit enhances reliability, and lets you share spares across multiple server platforms.Error-Correcting Code (ECC) memory protects business from data loss and unplanned system downtime.The HPE ProLiant ML30 Gen10 server offers a complete set of embedded HPE Integrated Lights Out (iLO 5) for Gen10 Servers management features, which includes HPE iLO with Agentless Management, Active Health System, and intelligent provisioning. -
Security Innovations
The HPE ProLiant ML30 Gen10 server is one of the Hewlett Packard Enterprise industry-standard servers with major firmware anchored directly into the silicon security protection built-in across the server lifecycle, starting with silicon root of trust.Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and reliably store artifacts used to authenticate the server. -
Industry-Leading Services and Ease of Deployment
The HPE ProLiant ML30 Gen10 server comes with a complete set of services from HPE Pointnext, delivering confidence, reducing risk, and helping you realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Service professionals understand customer challenges and design an enhanced solution. Professional Services enable rapid deployment of solutions and Operational Services provide ongoing support.Services provided under Operational Services include: HPE GreenLake Flex Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services, and multivendor coverage.Hewlett Packard Enterprise IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
- HPE ProLiant ML30 Gen10 Entry - tower Xeon E-2124 3.3 GHz - 8 GB - no HDD
- Server - tower
- Height (Rack Units)
- 4U
- Localisation
- Region: United Kingdom, Europe
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E-2124 / 3.3 GHz (up to 4.3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-21333
- Storage Controller
- RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software RAID)
- Server Storage Bays
- Non-hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200 - up to
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 17.5 cm x 47.5 cm x 36.83 cm
- 10.1 kg
- Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- Server
- Product Form Factor
- Tower - 4U
- 1-way
- Internal Bays Qty
- 4
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E-2124
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 4.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C246
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software RAID
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" LFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 2 (total) / 2 (free) x M.2 Card
- 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 6 x USB 3.0 (1 front, 4 rear, 1 internal) , 1 x USB 2.0 (1 in front)
- Included Accessories
- System fan
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- EMC, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1, UEFI
- Power supply
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 350 Watt
- 17.5 cm
- 47.5 cm
- 36.83 cm
- 10.1 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
