HPE ProLiant MicroServer Gen10 Plus v2 Performance 2 ultra micro tower Xeon E-2314 2.8 GHz 16GB 1TB
Quicklinx: HTPNWS00 Mfr#: P54654-421
Case Style: Tower
Processor Type: Xeon
Hard Disk Capacity: 1TB
Processor Speed: 2.8GHz
  • Xeon
£1,691.63 ex VAT
£2,029.95 inc VAT
Are you a small office, home office, or small business with branch offices looking to build a customized solution for your office? The HPE ProLiant MicroServer Gen10 Plus v2 server delivers an affordable compact yet powerful entry-level server that you can customize for on-premises or for hybrid cloud possibilities. It has the same compact form factor as the previous version and can be placed flat or vertically depending on your space. Powerful processors build compute performance as well as security and remote management into the server with HPE iLO Silicon Root of Trust from HPE iLO.
HPE ProLiant MicroServer Gen10 Plus v2 Performance 2 - ultra micro tower Xeon E-2314 2.8 GHz - 16 GB - HDD 1 TB
Server - ultra micro tower
Region: EMEA
Server Scalability
1-way
1 x Intel Xeon E-2314 / 2.8 GHz (up to 4.5 GHz, (Quad-Core)
Processor Socket
LGA1200 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s) (Intel VROC SATA Software RAID)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
No graphics
1GbE
(50/60 Hz)
OS Provided
No operating system
24.5 cm x 24.5 cm x 11.89 cm
4.23 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Server
Product Form Factor
Ultra micro tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Server Scalability
1-way
Internal Bays Qty
4
Region: EMEA
Processor / Chipset
CPU
Intel Xeon E-2314
Clock Speed
2.8 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1200 Socket
Chipset Type
Intel C252
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
3200 MHz
Rated Memory Speed
3200 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Business critical, advanced format 512n
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Video Interfaces
DisplayPort, VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
Intel I350-AM4
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
ACPI support, PXE support, Wake on LAN (WoL)
Bays
4 (total) / 3 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 4.0 x16 - low-profile , 1 (total) / 1 (free) x expansion slot (iLO Enablement Kit slot)
1 x VGA , 1 x DisplayPort , 4 x USB 3.2 Gen 1 - Type A (3 rear, 1 internal) , 2 x USB 3.2 Gen 2 - Type A (2 in front) , 1 x USB 2.0 - Type A (1 rear) , 4 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, CISPR 32, EN 55032, EN55024, FCC CFR47 Part 15, ICES-003, CNS 13438, GB 9254, K32, K24, EN 61000-3-2, EN 61000-3-3
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
180 watt
Operating System / Software
OS Provided
No operating system
24.5 cm
24.5 cm
11.89 cm
4.23 kg
8 - 90% RH (non-condensing)
Sound Emission
24 dBA
Warranty Packs (1)
HTPN HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,060.57
Other bundles (1)
HTPN HP iLO Adv incl 3yr TS U E-LTU In Stock £317.96
Case Style: Tower
Brand: HPE
Price Range Ex VAT: £1500+
