9 Reasons to buy an HP ProLiant MicroServer!
- 1. Saves time - Buy a complete end-to-end server solution from HP, saving time evaluating technology from multiple vendors.
- 2. Saves money - Benefit from lower integration and maintenance costs (as each piece of the portfolio is designed to work well on its own or as part of networked system), lower running costs (HP MicroServer saves energy, so it costs less to run) and protect your investment in existing office equipment (with a very low 200-watt, 85% efficient power supply).
- 3. Increases efficiency - Manages and safeguards business information from one central location, thanks to product features that enable simpler business processes.
- 4. Builds confidence - Rest-assured that a dependable, all-HP technology suite will work together with no hassles or worries.
- 5. Improves communications and collaboration - Boosts worker productivity and builds customer satisfaction and loyalty.
- 6. Easily expands capacity - Using plug-and-play drives.
- 7. Quiet - With an acoustic level of only 21.4dBA making it quieter than a library.
- 8. Sharing options - Share files, printers and internet access across the PCs in the office.
- 9. Bring the benefits home! - Now certified for use with Windows Home Server.
You have multiple versions of files floating around the company and maintaining control of document versions is becoming a challenge - there is no central data storage. You need to improve communication and work processes with employees or customers. You want to make sure that you can make the most of your existing computers and office equipment.
The HP ProLiant MicroServer is a general purpose server that can provide a platform to organize and safeguard your business information, allow effective communication with customers and make the most of your existing office equipment and resources. The HP MicroServer is a cost effective starter server for businesses and it can take your business to the next level of productivity and efficiency.
Simple To Own and Easy To Use
The HP ProLiant MicroServer provides your business with a server at personal computing costs, giving you more productivity for your dollars.The HP ProLiant MicroServer is easy to install and service so that adding disk drives or peripherals requires a minimal effort for your staff.At a 22 dBA noise level, the ProLiant MicroServer is quiet for ergonomic working environments.The HP ProLiant MicroServer form factor is space-saving, making it ideal for small office environments. -
Reliability and Expandability
The HP ProLiant MicroServer offers a key feature called error checking and correction (ECC) memory, which reduces the likelihood of memory failures-a concern for your business.Supports RAID 0 and 1 which prevents data loss and facilitates around the clock reliability for your HP ProLiant MicroServer providing peace of mind.With up to four large form factor (LFF) SATA pluggable hard disks and up to 8 GB of RAM the HP ProLiant MicroServer gives you room to grow. -
Proven HP Dependability and Support
HP conducts some of the most rigorous and thorough testing in the industry for the HP ProLiant MicroServer.System testing and process control the most dependable products.Backed by worldwide network of HP trained service.
- HPE ProLiant MicroServer - ultra micro tower - Turion II Neo N40L 1.5 GHz - 2 GB - HDD 250 GB
- Server - ultra micro tower - system password
- Localisation
- Region: Europe
- Server Scalability
- 1-way
- Processor
- 1 x AMD Turion II Neo N40L / 1.5 GHz (Dual-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB (2 x 1 MB)
- RAM
- 2 GB (installed) / 8 GB (max) - DDR3 SDRAM - ECC - PC3-10600
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- HDD 250 GB - SATA 3Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Shared Video Memory (UMA)
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Windows Server Certified
- This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
- 21 cm x 26 cm x 26.7 cm
- 6 kg
- Limited warranty - parts - 1 year - response time: next day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Ultra micro tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- AMD Turion II Neo N40L
- Clock Speed
- 1.5 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB (2 x 1 MB)
RAM
- Installed Size
- 2 GB / 8 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 800 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 2 GB
Hard Drive
- HDD
- Capacity
- 1 x 250 GB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Max Allocated RAM Size
- 128 MB
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- PCI Express x1
- Ethernet Controller
- HP NC107i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" LFF
- Slots
- 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, low-profile , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, low-profile , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU
- 1 x VGA , 6 x USB 2.0 (2 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x eSATA 3Gb/s
- System password
- ACPI 2.0, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply
- Voltage Required
- Power Provided
- 150 Watt
Operating System / Software
- OS Certified
- Microsoft Windows Server, Red Hat Enterprise Linux
- 21 cm
- 26 cm
- 26.7 cm
- 6 kg
- 10 °C
- 35 °C
- 10 - 90%
Resources
The following resources are available for the HPE ProLiant Microserver G7 Turion II Neo N40L 1.5 GHz 2GB 250GB
- Documentation
- £500 Cash Back Claim Form - March 2013
- £100 Cash Back Microserver Feb
- HP ROK Cash Back - April 13
- HP ROK Cash Back - July 13
- HP ROK Cash Back - May 13
- Feb Claim Form
- October ROK Claim Form
- ML110 Server Cash Back
- Microserver Cash Back Claim Form
- HP ROK Cash Back December January
Customer reviews
Write a review for the HPE ProLiant Microserver G7 Turion II Neo N40L 1.5 GHz 2GB 250GB here!
Fantastic Machine - However you look at it
Reviewed by Anonymous Review Posted 05/07/2012
I run my own 'micro-business' and ever since setting it up have looked at a variety of backup solutions. Many have proved complicated and unreliable. With 8 PCs in my network - and no desire to spend hours acquanting myself with Windows Server (for business) - I bought one of these boxes and a copy of Windows Home Server 2011. I also upgraded RAM to 8GB and added a 2TB HDD. Build quality is superb for the twice the money. It's quiet (although some reviews suggest that not all N40Ls are equally quiet)and there are many neat touches (like the HDD mounting bolts supplied inside the case. The £100 cashback offer makes this too good to miss. Aamazed that the N40L has not been picked-up by the press. Fits a sizable niche in the market. Why pay more for a larger server or less capable NAS?
Overall
Ease of use
Value for money
Quiet, Fast and a Bargain
Reviewed by Andrew at Watchbattery.co.uk. Review Posted 13/09/2012
I bought one of these servers to replace an IBM smalll business server which failed. Since then I have bought one as a file server and another for a Home Cinema server, all running Windows Server OSs.
With the £100 cash back being extended (again) the price of this server becomes a bit of a no brainer decision.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
