HPE ProLiant MicroServer G7 AMD Turion N54L 4GB No HDD
Quicklinx: 9JX8WS00 Mfr#: 744900-421
  • Red Hat Enterprise Linux
Is your growing business ready for its first server to make you more productive and to enhance your success? The HP ProLiant MicroServer is a general purpose server that can provide a platform to organize and safeguard your business information, allowing effective communication with customers and making the most of your existing office equipment and resources. The HP ProLiant MicroServer is a cost-effective starter server for businesses with fewer than ten clients and it can take your business to the next level of productivity and efficiency. With a small form factor that is easy to use and service, it helps you drive down expenses while improving your success.
  • Simple To Own and Easy To Use
    The HP ProLiant MicroServer provides your business with a server at personal computing costs, giving you more productivity for your dollars.The HP ProLiant MicroServer is easy to install and service so that adding disk drives or peripherals requires a minimal effort for your staff.At a 22 dBA noise level, the ProLiant MicroServer is quiet for ergonomic working environments.The HP ProLiant MicroServer form factor is space-saving, making it ideal for small office environments.
  • Reliability and Expandability
    The HP ProLiant MicroServer offers a key feature called error checking and correction (ECC) memory, which reduces the likelihood of memory failures-a concern for your business.Supports RAID 0 and 1 which prevents data loss and facilitates around the clock reliability for your HP ProLiant MicroServer providing peace of mind.With up to four large form factor (LFF) SATA pluggable hard disks and up to 8 GB of RAM the HP ProLiant MicroServer gives you room to grow.
  • Proven HP Dependability and Support
    HP conducts some of the most rigorous and thorough testing in the industry for the HP ProLiant MicroServer.System testing and process control the most dependable products.Backed by worldwide network of HP trained service.
HPE ProLiant MicroServer G7 - ultra micro tower - Turion II Neo N54L 2.2 GHz - 4 GB - no HDD
Server - ultra micro tower - system password
Region: Europe
Server Scalability
1-way
1 x AMD Turion II Neo N54L / 2.2 GHz (Dual-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
OS Provided
No operating system
21 cm x 26 cm x 26.7 cm
5.98 kg
Limited warranty - parts - 1 year
Server
Recommended Use
Small business, corporate business
Product Form Factor
Ultra micro tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 8 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
800 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Max Allocated RAM Size
128 MB
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express x1
Ethernet Controller
HP NC107i
Remote Management Protocol
IPMI 2.0
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 4 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe x16 - half-length, low-profile , 1 (total) / 1 (free) x PCIe x1 - half-length, low-profile , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU
1 x VGA , 7 x USB 2.0 (2 front, 4 rear, 1 internal) , 1 x LAN (Gigabit Ethernet) , 1 x eSATA 3Gb/s
System password
ACPI 2.0, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
Power supply
Power Provided
150 Watt
Operating System / Software
OS Provided
No operating system
OS Certified
Microsoft Windows Server, Red Hat Enterprise Linux
21 cm
26 cm
26.7 cm
5.98 kg
10 °C
35 °C
10 - 90%
Sound Emission
21.3 dBA
