HPE ProLiant DL560 Gen10 2 x Intel Xeon Gold 6130 64GB
Quicklinx: F8LWWS00 Mfr#: 875807-B21
Case Style: Rack-mountable
Processor Type: Xeon Gold
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 64GB
  • Red Hat Enterprise Linux
£5,909.96 ex VAT
£7,091.95 inc VAT
Looking for a dense but highly scalable server for your data center application and virtualization needs? HPE ProLiant DL560 Gen10 Server is a high-density, 4P server with high-performance, scalability, and reliability, in a 2U chassis. Supporting the Intel Xeon Scalable processors with up to a 68% performance gain , the HPE ProLiant DL560 Gen10 Server offers greater processing power, up to 3 TB of faster memory, and I/O of up to eight PCIe 3.0 slots. In addition if offers the intelligence and simplicity of automated management with HPE OneView and HPE Integrated Lights Out 5 (iLO 5). The HPE ProLiant DL560 Gen10 Server is the ideal server for business-critical workloads, virtualization, server consolidation, database, business processing, and general 4P data-intensive applications where data center space and the right performance are paramount.
  • Scalable 4P Performance in a Dense 2U Form Factor
    HPE ProLiant DL560 Gen10 Server provides 4P computing in a dense 2U form factor and supports up to four Intel Xeon Platinum (8100 series) and Gold (6100 and 5100 series) processors which provide up to 68% more processor performance and 27% more cores than the previous generation.Up to 48 DIMM slots which support up to 3 TB for 2666 MT/s DDR4 HPE SmartMemory. HPE DDR4 SmartMemory improves workload performance and power efficiency while reducing data loss and downtime with enhanced error handling.Choice of HPE FlexibleLOM adapters offers range of networking bandwidth (1GbE to 25GbE) and fabric so you can adapt and grow to changing business needs.HPE Innovation with Intelligent System Tuning enhances workload performance using customized profiles to tune internal resources; improves workloads such as high frequency trading with jitter smoothing and provides added performance with core boosting SKUs.
  • Flexible New Generation Expandability and Reliability for Multiple Workloads
    HPE ProLiant DL560 Gen10 Server has a flexible processor tray allowing to scale up from two to four processors only when you need, saving on upfront costs. The flexible drive cage design supports up to 24 SFF SAS/SATA with a maximum of 12 NVMe drives.Supports up to eight PCIe 3.0 expansion slots for graphical processing units (GPUs) and networking cards offering increased I/O bandwidth and expandability.Up to four, 96% efficient HPE 800W or 1600W Flexible Slot Power Supplies , which enable higher power redundant configurations and flexible voltage ranges. The slots provide the capability to trade-off between 2+2 power supplies or use as extra PCIe slots.
  • Secure and Reliable
    HPE iLO 5 enables the world's most secure industry standard servers with HPE Silicon Root of Trust technology to protect your servers from attacks, detect potential intrusions and recover your essential server firmware securely.Millions of lines of firmware code run before server operating system boots and with Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to rollback to the to last known good state or factory settings after detection of compromised code.Additional security options are available with, Trusted Platform Module (TPM), to prevent unauthorized access to the server and safely stores artifacts used to authenticate the server platforms while the Intrusion Detection Kit logs and alerts when the server hood is removed.
  • Agile Infrastructure Management for Accelerating IT Service Delivery
    With HPE ProLiant DL560 Gen10 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.A suite of embedded and downloadable tools is available for server lifecycle management including Unified Extensible Firmware Interface (UEFI), Intelligent Provisioning; HPE iLO 5 to monitor and manage; HPE iLO Amplifier Pack, Smart Update Manager (SUM), and Service Pack for ProLiant (SPP).Services from HPE Pointnext simplify the stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design a better solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant DL560 Gen10 Entry - rack-mountable - Xeon Gold 6130 2.1 GHz - 64 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
4-way
2 x Intel Xeon Gold 6130 / 2.1 GHz (3.7 GHz) (16-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
44 MB L3 Cache
Cache Per Processor
22 MB
RAM
64 GB (installed) / 768 GB (max) - DDR4 SDRAM - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
GigE, 10 GigE
Power Redundancy
44.54 cm x 75.47 cm x 8.75 cm
18.45 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
4-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
16-core
CPU Qty
2
Max CPU Qty
4
CPU Upgradability
Upgradable
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 44 MB
Cache Per Processor
22 MB
RAM
Installed Size
64 GB / 768 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
24 (Total) / 20 (empty)
Registered, HP SmartMemory, 6-channel memory architecture
Configuration Features
4 x 16 GB
RAM Supported
PC4-20800 - 768 GB registered , PC4-20800 - 1.5 TB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x 10 Gigabit Ethernet
Ethernet Controller
HPE 533FLR-T
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 1 (free) x external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
24 (total) / 20 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - three-quarter-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - three-quarter-length, full-height , 2 (total) / 2 (free) x M.2 Card , 1 (total) / 1 (free) x microSD Card (internal)
1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x HP iLO - RJ-45 , 1 x HP iLO (1 in front) , 2 x USB 2.0 , 5 x USB 3.0 (1 front, 2 rear, 2 internal)
HPE Easy Install Rails, cable management assembly, 6 x redundant hot plug fans
WEEE, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Installed Qty
2
Max Supported Qty
2
Nominal Voltage
Power Provided
1600 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
44.54 cm
75.47 cm
8.75 cm
18.45 kg
10 °C
35 °C
8 - 90% (non-condensing)
Brand: HPE
Price Range Ex VAT: 1500+
