Building on HPE ProLiant as the intelligent foundation for hybrid cloud, the HPE ProLiant DL385 Gen10 Plus server offers a powerful processor. With 32 DIMMs for memory up to 3200 MHz, the HPE ProLiant DL385 Gen10 Plus server delivers low cost virtual machines (VMs) with unprecedented security. Equipped with PCIe Gen4 capabilities, HPE ProLiant DL385 Gen10 Plus offers improved data transfer rates and higher networking speeds. Combined with a better balance of processor cores, memory and I/O, HPE ProLiant DL385 Gen10 Plus is an ideal choice for virtualization, and memory-intensive and HPC workloads.
Flexible Design
The HPE ProLiant DL385 Gen10 Plus server has an adaptable chassis, including the modular drive bays that can be configured with up to 28 SFF, up to 20 LFF, or up to 16 NVMe drive options.The redesigned HPE Smart Array Essential and Performance RAID Controllers offer performance and flexibility for additional features including the ability to operate in both SAS and HBA mode.Choice of OCP 3.0 or PCIe standup adapters which offers a choice of networking bandwidth and fabric, making it scalable for changing business needs.The HPE ProLiant DL385 Gen10 Plus supports a wide range of operating systems, making it suitable for most environments. -
Automation
The HPE ProLiant DL385 Gen10 Plus server features HPE iLO 5 which monitors servers for ongoing management, service alerting, reporting, and remote management to resolve issues quickly and keep your business running from anywhere in the world.HPE OneView is an automation engine that transforms compute, storage, and networking into software-defined infrastructure to automate tasks and speed business process implementations.HPE InfoSight provides built-in AI that predicts problems before they happen, proactively resolves issues, and continually learns as it analyzes data-making every system smarter and more reliable.HPE iLO RESTful API feature provides iLO RESTful API extensions to Redfish, allowing you to take full advantage of the wide range of value-added API features and integrate easily with leading orchestration tools. -
Security
The HPE ProLiant DL385 Gen10 Plus server is built with Silicon Root of Trust as an immutable fingerprint in the iLO silicon. The silicon root of trust validates the lowest level firmware to BIOS and software to verify a known good state.Tied into the silicon root of trust is the AMD Secure Processor, a dedicated security processor embedded in the AMD EPYC system on a chip (SoC). The security processor manages secure boot, memory encryption, and secure virtualization.Run Time Firmware Validation validates the iLO and UEFI/BIOS firmware at runtime. Notification and automated recovery is executed on detection of compromised firmware.If system corruption has been detected, Server System Restore will automatically alert iLO Amplifier Pack to initiate and manage the system recovery process, avoiding lasting damage to your business by quickly restoring firmware to the factory settings or the last known authenticated safe setting. -
Optimization
The HPE ProLiant DL385 Gen10 Plus server supports HPE Right Mix Advisor to provide data-driven guidance and drive the ideal hybrid cloud mix for workloads, allowing for intelligent planning, speeding migrations from months to weeks, and controlling the cost of migration.HPE GreenLake Flex Capacity provides pay-per-use IT consumption on-premises with real-time tracking and metering of resource usage, so you have the capacity you need to deploy quickly, pay for the exact resources you consume, and avoid over provisioning.HPE Foundation Care helps when there is a hardware or software problem, offering several response levels dependent on IT and business requirements.HPE Proactive Care is an integrated set of hardware and software support including an enhanced call experience with start to finish case management, helping resolve incidents quickly and keeping IT reliable and stable.HPE Financial Services helps you transform to a digital business with financing options and trade-in opportunities that align to your business goals.
- HPE ProLiant DL385 Gen10 Plus - rack-mountable EPYC 7302 3 GHz - 32 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Localisation
- Region: Worldwide
- Server Scalability
- 2-way
- Processor
- 1 x AMD EPYC 7302 / 3 GHz (16-core)
- Cache Memory
- 128 MB
- Cache Per Processor
- 128 MB
- RAM
- 32 GB DDR4 SDRAM
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- No graphics - up to
- Networking
- 1GbE, 10GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- Software Included
- HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
- 44.54 cm x 71.1 cm x 8.73 cm
- 19.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Led panel
- 2-way
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- AMD EPYC 7302
- Clock Speed
- 3 GHz
- Number of Cores
- 16-core
- CPU Qty
- 1
- Max CPU Qty
- 2
Cache Memory
- Installed Size
- 128 MB
- 128 MB
RAM
- Installed Size
- 32 GB
- Technology
- DDR4 SDRAM
- Rated Memory Speed
- 3200 MHz
- Registered
- Configuration Features
- 2 x 16 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, 1ADM, 10ADM
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
- Ethernet Ports
- 2 x 10 Gigabit Ethernet
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
- Bays
- 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x8
- 1 x HPE iLO , 2 x LAN (10Gigabit Ethernet)
- Included Accessories
- HPE Easy Install Rails, 4 standard fans
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
Operating System / Software
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 3.0
- 44.54 cm
- 71.1 cm
- 8.73 cm
- 19.7 kg
Warranty Packs (1)
Internal Hard Drives (3)
HPE 300GB SAS 15K SFF SC DS-Stock | In Stock | £456.47 |
HPE 600GB SAS 10K SFF SC DS HDD | In Stock | £160.48 |
HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s | In Stock | £162.89 |
Other bundles (2)
HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack | In Stock | £196.94 |
HP iLO Adv incl 3yr TS U E-LTU | In Stock | £309.90 |
