HPE ProLiant DL385 Gen10 Plus AMD EPYC 7302 32GB Rack Mount Server
Quicklinx: FN9CWS00 Mfr#: P07596-B21
Case Style: Rack-mountable
Processor Type: EPYC
Hard Disk Capacity: 0GB
Processor Speed: 3GHz, 3GHz
Installed Memory: 32GB
£7,444.69 ex VAT
£8,933.62 inc VAT
Building on HPE ProLiant as the intelligent foundation for hybrid cloud, the HPE ProLiant DL385 Gen10 Plus server offers a powerful processor. With 32 DIMMs for memory up to 3200 MHz, the HPE ProLiant DL385 Gen10 Plus server delivers low cost virtual machines (VMs) with unprecedented security. Equipped with PCIe Gen4 capabilities, HPE ProLiant DL385 Gen10 Plus offers improved data transfer rates and higher networking speeds. Combined with a better balance of processor cores, memory and I/O, HPE ProLiant DL385 Gen10 Plus is an ideal choice for virtualization, and memory-intensive and HPC workloads.
  • Flexible Design
    The HPE ProLiant DL385 Gen10 Plus server has an adaptable chassis, including the modular drive bays that can be configured with up to 28 SFF, up to 20 LFF, or up to 16 NVMe drive options.The redesigned HPE Smart Array Essential and Performance RAID Controllers offer performance and flexibility for additional features including the ability to operate in both SAS and HBA mode.Choice of OCP 3.0 or PCIe standup adapters which offers a choice of networking bandwidth and fabric, making it scalable for changing business needs.The HPE ProLiant DL385 Gen10 Plus supports a wide range of operating systems, making it suitable for most environments.
  • Automation
    The HPE ProLiant DL385 Gen10 Plus server features HPE iLO 5 which monitors servers for ongoing management, service alerting, reporting, and remote management to resolve issues quickly and keep your business running from anywhere in the world.HPE OneView is an automation engine that transforms compute, storage, and networking into software-defined infrastructure to automate tasks and speed business process implementations.HPE InfoSight provides built-in AI that predicts problems before they happen, proactively resolves issues, and continually learns as it analyzes data-making every system smarter and more reliable.HPE iLO RESTful API feature provides iLO RESTful API extensions to Redfish, allowing you to take full advantage of the wide range of value-added API features and integrate easily with leading orchestration tools.
  • Security
    The HPE ProLiant DL385 Gen10 Plus server is built with Silicon Root of Trust as an immutable fingerprint in the iLO silicon. The silicon root of trust validates the lowest level firmware to BIOS and software to verify a known good state.Tied into the silicon root of trust is the AMD Secure Processor, a dedicated security processor embedded in the AMD EPYC system on a chip (SoC). The security processor manages secure boot, memory encryption, and secure virtualization.Run Time Firmware Validation validates the iLO and UEFI/BIOS firmware at runtime. Notification and automated recovery is executed on detection of compromised firmware.If system corruption has been detected, Server System Restore will automatically alert iLO Amplifier Pack to initiate and manage the system recovery process, avoiding lasting damage to your business by quickly restoring firmware to the factory settings or the last known authenticated safe setting.
  • Optimization
    The HPE ProLiant DL385 Gen10 Plus server supports HPE Right Mix Advisor to provide data-driven guidance and drive the ideal hybrid cloud mix for workloads, allowing for intelligent planning, speeding migrations from months to weeks, and controlling the cost of migration.HPE GreenLake Flex Capacity provides pay-per-use IT consumption on-premises with real-time tracking and metering of resource usage, so you have the capacity you need to deploy quickly, pay for the exact resources you consume, and avoid over provisioning.HPE Foundation Care helps when there is a hardware or software problem, offering several response levels dependent on IT and business requirements.HPE Proactive Care is an integrated set of hardware and software support including an enhanced call experience with start to finish case management, helping resolve incidents quickly and keeping IT reliable and stable.HPE Financial Services helps you transform to a digital business with financing options and trade-in opportunities that align to your business goals.
HPE ProLiant DL385 Gen10 Plus - rack-mountable EPYC 7302 3 GHz - 32 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x AMD EPYC 7302 / 3 GHz (16-core)
Cache Memory
128 MB
Cache Per Processor
128 MB
RAM
32 GB DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
No graphics - up to
1GbE, 10GbE
Power Redundancy
Optional
Software Included
HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
44.54 cm x 71.1 cm x 8.73 cm
19.7 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel
Server Scalability
2-way
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
AMD EPYC 7302
Clock Speed
3 GHz
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
Cache Memory
Installed Size
128 MB
Cache Per Processor
128 MB
RAM
Installed Size
32 GB
DDR4 SDRAM
Rated Memory Speed
3200 MHz
Registered
Configuration Features
2 x 16 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, 1ADM, 10ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Ethernet Ports
2 x 10 Gigabit Ethernet
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Bays
8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x8
1 x HPE iLO , 2 x LAN (10Gigabit Ethernet)
HPE Easy Install Rails, 4 standard fans
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
500 Watt
Operating System / Software
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
3.0
44.54 cm
71.1 cm
8.73 cm
19.7 kg
Warranty Packs (1)
FN9C HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,014.27
Internal Hard Drives (3)
FN9C HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD In Stock £237.80
FN9C HPE 300GB SAS 15K SFF SC DS-Stock In Stock £456.47
FN9C HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £164.52
Other bundles (1)
FN9C HP iLO Adv incl 3yr TS U E-LTU In Stock £311.60
Brand: HPE
Price Range Ex VAT: £1500+
