HPE ProLiant DL385 Gen10 AMD EPYC 7302 16GB Rack Mount Server
Quicklinx: FN98WS00 Mfr#: P16694-B21
Do you need a platform purpose-built to address your virtualized and memory-centric workloads? Try something EPYC. Hewlett Packard Enterprise is extending the worlds' most secure industry standard servers to include the HPE ProLiant DL385 Gen10 Server, utilizing the AMD EPYC 7000 Series processors. This platform has been designed with the security you need and the flexibility you require to accommodate the most demanding enterprise workloads. The HPE ProLiant DL385 Gen10 Server delivers a low cost virtual machine (VM) with unprecedented security.
  • Security Innovations
    HPE ProLiant DL385 Gen10 Server has security protection built in across the server life cycle starting with Silicon Root of Trust. Only Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon.Millions of lines of firmware code run before server operating system boots. What's more, with Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.The AMD EPYC processor provides several security related features, including AMD secure processor, secure memory encryption (SME), and secure encrypted virtualization (SEV). These features are used to help enable key security functionality including Secure Root-of-Trust, Secure Run, and Secure Move.
  • Flexible Design
    HPE ProLiant DL385 Gen10 Server has an adaptable chassis, including the modular drive bays that can be configured with up to 30 SFF, up to 19 LFF or up to 24 NVMe drive options along with support for up to 3 double wide GPU options.HPE Smart Array S100i Software RAID ships standard for embedded m.2 boot, and the redesigned HPE Smart Array Essential and Performance RAID Controllers for performance or additional features including the ability to operate in both SAS and HBA mode.Along with an embedded 4x1GbE, you have a choice of HPE FlexibleLOM or PCIe standup adapters which offer a choice of networking bandwidth (1GbE to 4x10GbE) and fabric so you can adapt and grow to changing business needs.This server supports a wide range of operating systems making it suitable for most environments.
  • World-class Performance
    HPE ProLiant DL385 Gen10 Server supports industry standard technology leveraging the AMD EPYC 7000 Series Processor with up to 32 cores, 12 Gb SAS and 4.0 TB of HPE DDR4 SmartMemory.Supports up to three double wide or five single wide graphic processing units (GPUs) for workload acceleration.
  • Proven Industry Leading Services and Ease of Deployment
    HPE ProLiant DL385 Gen10 Server comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an optimal solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE Financial Services helps you transform to a digital business with financing option and trade-in opportunities that align to your business goals.
HPE ProLiant DL385 Gen10 Performance - rack-mountable - EPYC 7302 3 GHz - 16 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x AMD EPYC 7302 / 3 GHz (, up to 3.3 GHz, (16-core)
Cache Memory
128 MB L3 Cache
Cache Per Processor
128 MB
RAM
16 GB (installed) / 1 TB (max) - DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
1GbE
Power Redundancy
OS Provided
No operating system
44.55 cm x 67.94 cm x 8.73 cm
14.9 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
AMD EPYC 7302
Clock Speed
3 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 128 MB
Cache Per Processor
128 MB
RAM
Installed Size
DDR4 SDRAM
DIMM 288-pin
Slots
32 (Total) / 31 (empty)
Registered, dual channel memory architecture, HPE SmartMemory, slots 17 - 32 are available in two-processor configuration only
Configuration Features
1 x 16 GB
RAM Supported
PC4-21333 - 4 TB Load-Reduced , PC4-21333 - 1 TB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA, DisplayPort
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 366FLR
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 0 (free) x FlexibleLOM , 3 (total) / 3 (free) x PCIe 3.0 x8 - full-length, full-height (processor 2) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (processor 2) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (processor 2)
1 x HPE iLO (service port) , 1 x HPE iLO , 3 x USB 3.0 (1 front, 2 rear) , 4 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort
HPE Easy Install Rails, 4 standard fans
AES, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
1
Max Supported Qty
2
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Provided
No operating system
OS Certified
Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, SuSE Linux Enterprise Server 12 SP3, Red Hat Enterprise Linux 7.4, VMware ESXi 6.5 update 1, VMware ESXi 6.5 update 2, VMware ESXi 6.7
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.55 cm
67.94 cm
8.73 cm
14.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
37 dBA
Warranty Packs (2)
FN98 HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,060.57
FN98 HPE Tech Care Essential Service Post Warranty - extended service agreement - 1 year - on-site In Stock £2,719.16
Internal Hard Drives (1)
FN98 HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £234.83
Other bundles (3)
FN98 HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack In Stock £196.94
FN98 HP iLO Adv incl 3yr TS U E-LTU In Stock £310.83
FN98 HPE 96W Smart Storage Battery In Stock £77.47
