HPE ProLiant DL380 Gen10 Intel Xeon Silver 4214 16GB
Quicklinx: F7NMWS00 Mfr#: P02468-B21
Case Style: Rack-mountable
Processor Type: Xeon Silver
Hard Disk Capacity: 0GB
Processor Speed: 2.2GHz
Installed Memory: 16GB
  • Red Hat Enterprise Linux
£3,644.86 ex VAT
£4,373.83 inc VAT
The HPE ProLiant DL380 Gen10 server delivers great security, performance and expandability. It's securely designed to reduce costs and complexity.
HPE ProLiant DL380 Gen10 SMB - rack-mountable - Xeon Silver 4214 2.2 GHz - 16 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x Intel Xeon Silver 4214 / 2.2 GHz (, up to 3.2 GHz, (12-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
16.5 MB L3 Cache
Cache Per Processor
16.5 MB
RAM
16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P816i-a)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
1GbE
Power Redundancy
Software Included
HPE Server UEFI
44.54 cm x 73.02 cm x 8.73 cm
17.1 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Hot-Swap Bays Qty
12
Region: Worldwide
Processor / Chipset
CPU
Clock Speed
2.2 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
12-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 16.5 MB
Cache Per Processor
16.5 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory, 6-channel memory architecture
Configuration Features
1 x 16 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
16
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
12 (total) / 12 (free) x hot-swap 3.5" LFF
Slots
1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
4 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear) , 8 x SATA-600 / SAS 3.0 , 1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal)
Cable management arm, 6 performance fans, LFF Easy Install rails
AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
800 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
Software
HPE Server UEFI
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.54 cm
73.02 cm
8.73 cm
17.1 kg
10 °C
35 °C
8 - 90% (non-condensing)
Warranty Packs (1)
F7NM HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,212.69
Internal Hard Drives (1)
F7NM HPE Midline 4 TB - SATA 6Gb/s HDD In Stock £171.97
Other bundles (5)
F7NM HPE HP Ethernet 1Gb 4-port 331T Adapter In Stock £81.28
F7NM HPE HP Ethernet 1GB 2P 332T Adaptor In Stock £39.09
F7NM HPE Ethernet 1GB 4-Port Adapter In Stock £47.64
F7NM HPE Ethernet 1GB 4-Port 366T Adapter In Stock £164.89
F7NM HPE 96W Smart Storage Battery In Stock £62.94
Brand: HPE
Price Range Ex VAT: £1500+
