The HPE ProLiant DL380 Gen10 server delivers great security, performance and expandability. It's securely designed to reduce costs and complexity.
Flexible Design Making Your Investment Expand As Your Business Needs Grow
The HPE ProLiant DL380 Gen10 Server has an adaptable chassis, including new HPE modular drive bay configuration options with up to 30 SFF, up to 19 LFF or up to 20 NVMe drive options along with support for up to 3 double wide GPU options.HPE Persistent Memory, delivers unprecedented levels of performance and data resiliency for databases and analytic workloads. With up to 27x faster application checkpoint operations and 20x faster restores, HPE delivers the fastest persistent memory in the market at TB-scale.In conjunction with the embedded SATA HPE Dynamic Smart Array S100i Controller for boot, data and media needs, the redesigned HPE Smart Array Controllers allow you the flexibility to choose the optimal 12 Gb/s controller most suited to your environment, and operate in both SAS and HBA mode.Along with an embedded 4x1GbE, you have a choice of HPE FlexibleLOM or PCIe standup adapters which offer a choice of networking bandwidth (1GbE to 40GbE) and fabric so you can adapt and grow to changing business needs.Supporting a wide range of operating environments from Azure to Docker to ClearOS in addition to traditional OSes. -
Security Innovations
Only Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon. With security protection built in across the server life-cycle starting with Silicon Root of Trust.Millions of lines of firmware code run before server operating system boots and with Run-Time Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and securely store artifacts used to authenticate the server platforms while the Intrusion Detection kit logs and alerts when the server hood is removed. -
World-Class Performance
HPE innovation with Intelligent System Tuning optimizes workload performance using customized profiles to tune internal resources, with improved throughput for all workloads including latency-sensitive workloads such as high-frequency trading with jitter smoothing.The HPE ProLiant DL380 Gen10 Server supports industry standard technology leveraging the latest Intel Xeon Processor Scalable Family with up to 28 cores, 12 Gb SAS and 3.0 TB of HPE DDR4 SmartMemory.The HPE ProLiant DL380 Gen10 supports up to three double wide or five single wide GPUs for workload acceleration. -
Industry Leading Services and Ease of Deployment
The HPE ProLiant DL380 Gen10 Server comes with a complete set of HPE Technology Services, delivering confidence, reducing risk and helping customers realize agility and stability.HPE Pointnext Services simplifies all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an optimal solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: Flexible Capacity, Datacenter Care, Infrastructure Automation, Campus Care, Proactive Services and Multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
- HPE ProLiant DL380 Gen10 SMB - rack-mountable Xeon Silver 4208 2.1 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Localisation
- Region: Worldwide
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4208 / 2.1 GHz (up to 3.2 GHz, (8-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB L3 Cache
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (HPE Smart Array P408i-a)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- - up to
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Software Included
- HPE Server UEFI
- 44.54 cm x 67.94 cm x 8.73 cm
- 14.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Battery
- 2-way
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon Silver 4208
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- L3 Cache - 11 MB
- 11 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2933 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory, 6-channel memory architecture
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HPE 331i
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- Bays
- 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
- 4 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear) , 8 x SATA-600 / SAS 3.0 , 1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal)
- Included Accessories
- Cable management arm, 4 standard fans, SFF Easy install rails
- AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Certified
- CentOS, Microsoft Windows Server 2012 R2, VMware vSphere 6.0 (ESXi), SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, VMware vSphere 6.5, SuSE Linux Enterprise Server 12 SP2, ClearOS
- Software
- HPE Server UEFI
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 44.54 cm
- 67.94 cm
- 8.73 cm
- 14.9 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
Warranty Packs (1)
Other bundles (2)
HPE Ethernet 1GB 4-Port Adapter | In Stock | £51.30 |
HPE DL38X GEN10 Universal Media Bay | In Stock | £32.37 |
