HPE ProLiant DL380 Gen10 Intel Xeon Gold 6130 64GB
Quicklinx: F8LCWS00 Mfr#: P06423-B21
The HPE ProLiant DL380 Gen10 server delivers advanced security, performance and expandability. It is ideal for any server environment.
  • Flexible Design Making Your Investment Expand As Your Business Needs Grow
    The HPE ProLiant DL380 Gen10 Server has an adaptable chassis, including new HPE modular drive bay configuration options with up to 30 SFF, up to 19 LFF or up to 20 NVMe drive options along with support for up to 3 double wide GPU options.HPE Persistent Memory, delivers unprecedented levels of performance and data resiliency for databases and analytic workloads. With up to 27x faster application checkpoint operations and 20x faster restores, HPE delivers the fastest persistent memory in the market at TB-scale.In conjunction with the embedded SATA HPE Dynamic Smart Array S100i Controller for boot, data and media needs, the redesigned HPE Smart Array Controllers allow you the flexibility to choose the optimal 12 Gb/s controller most suited to your environment, and operate in both SAS and HBA mode.Along with an embedded 4x1GbE, you have a choice of HPE FlexibleLOM or PCIe standup adapters which offer a choice of networking bandwidth (1GbE to 40GbE) and fabric so you can adapt and grow to changing business needs.Supporting a wide range of operating environments from Azure to Docker to ClearOS in addition to traditional OSes.
  • Security Innovations
    Only Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon. With security protection built in across the server life-cycle starting with Silicon Root of Trust.Millions of lines of firmware code run before server operating system boots and with Run-Time Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and securely store artifacts used to authenticate the server platforms while the Intrusion Detection kit logs and alerts when the server hood is removed.
  • World-Class Performance
    HPE innovation with Intelligent System Tuning optimizes workload performance using customized profiles to tune internal resources, with improved throughput for all workloads including latency-sensitive workloads such as high-frequency trading with jitter smoothing.The HPE ProLiant DL380 Gen10 Server supports industry standard technology leveraging the latest Intel Xeon Processor Scalable Family with up to 28 cores, 12 Gb SAS and 3.0 TB of HPE DDR4 SmartMemory.The HPE ProLiant DL380 Gen10 supports up to three double wide or five single wide GPUs for workload acceleration.
  • Industry Leading Services and Ease of Deployment
    The HPE ProLiant DL380 Gen10 Server comes with a complete set of HPE Technology Services, delivering confidence, reducing risk and helping customers realize agility and stability.HPE Pointnext Services simplifies all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an optimal solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: Flexible Capacity, Datacenter Care, Infrastructure Automation, Campus Care, Proactive Services and Multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant DL380 Gen10 Performance - rack-mountable Xeon Gold 6130 2.1 GHz - 64 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x Intel Xeon Gold 6130 / 2.1 GHz (up to 3.7 GHz, (16-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
22 MB L3 Cache
Cache Per Processor
22 MB
RAM
64 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC - PC4-21333
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
- up to
Video Memory
16 MB
1GbE
Power Redundancy
44.55 cm x 73.07 cm x 8.74 cm
14.76 kg
Manufacturer Selling Program
HPE Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 22 MB
Cache Per Processor
22 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
24 (Total) / 22 (empty)
Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
2 x 32 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
1 x SATA
SATA 6Gb/s
Channel Qty
14
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
HPE Easy Install Rails, 4 standard fans, CPU standard heatsink
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
HPE Smart Buy
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.55 cm
73.07 cm
8.74 cm
14.76 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
31 dBA
Warranty Packs (1)
F8LC HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,188.31
Internal Hard Drives (3)
F8LC HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD In Stock £237.80
F8LC HPE 300GB SAS 15K SFF SC DS-Stock In Stock £456.47
F8LC HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £163.78
Other bundles (2)
F8LC HPE Ethernet 1GB 4-Port Adapter In Stock £48.36
F8LC HPE DL38X GEN10 Universal Media Bay In Stock £30.58
