The HPE ProLiant DL360 Gen10 server delivers security, agility and flexibility without compromise. Deploy, update, monitor and maintain with ease.
- HPE ProLiant DL360 Gen10 Entry - rack-mountable - Xeon Silver 4208 2.1 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4208 / 2.1 GHz (, up to 3.2 GHz, (8-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB L3 Cache
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
- Storage Controller
- SATA (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- Software Included
- HPE Server UEFI
- 43.46 cm x 70.7 cm x 4.29 cm
- 13.04 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 1U
- Built-in Devices
- Led panel
- 2-way
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon Silver 4208
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- L3 Cache - 11 MB
- 11 MB
RAM
- Installed Size
- 16 GB / 1.5 TB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2933 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank, slots 13 - 24 are available in two-processor configuration only
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software
- Channel Qty
- 14
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HPE 331i
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" LFF , 1 (total) / 1 (free) x external Universal Media Bay
- Slots
- 1 (total) / 1 (free) x FlexibleLOM (low-profile) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 (low-profile) , 1 (total) / 1 (free) x microSD Card (internal)
- 14 x SATA-600 , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HPE iLO - Type A (1 in front) , 2 x USB 3.0 (2 rear) , 1 x PoweredUSB 3.0 (1 in front) , 2 x USB 3.0 (1 front, 1 internal)
- Included Accessories
- CPU standard heatsink, 5 x standard hot plug fans, LFF Easy Install rails
- AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, FIPS 201 PIV, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
Operating System / Software
- OS Certified
- CentOS, Microsoft Windows Server 2012 R2, VMware vSphere 6.0 (ESXi), SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, VMware vSphere 6.5 (ESXi), SuSE Linux Enterprise Server 12 SP2, ClearOS
- Software
- HPE Server UEFI
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 43.46 cm
- 70.7 cm
- 4.29 cm
- 13.04 kg
- 10 °C
- 35 °C
Internal Hard Drives (1)
HPE Midline 4 TB - SATA 6Gb/s HDD | In Stock | £171.97 |
Other bundles (3)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.06 |
HPE Ethernet 1GB 4-Port 366T Adapter | In Stock | £164.89 |
