Does your data center need a secure, performance driven dense server that you can confidently deploy for virtualization, database, or high-performance computing? The HPE ProLiant DL360 Gen10 server delivers security, agility and flexibility without compromise.
- HPE ProLiant DL360 Gen10 Performance - rack-mountable - Xeon Gold 5118 2.3 GHz - 32 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Localisation
- Region: Worldwide
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Gold 5118 / 2.3 GHz (, up to 3.2 GHz, (12-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 16.5 MB L3 Cache
- Cache Per Processor
- 16.5 MB
- RAM
- 32 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC - PC4-21333
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (HPE Smart Array S100i SR Software)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Software Included
- HPE Server UEFI
- 43.46 cm x 70.7 cm x 4.29 cm
- 13.04 kg
- Manufacturer Selling Program
- HPE Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
- Server
- Product Form Factor
- Rack-mountable - 1U
- Built-in Devices
- Led panel, battery
- 2-way
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon Gold 5118
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 12-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- L3 Cache - 16.5 MB
- 16.5 MB
RAM
- Installed Size
- 32 GB / 1.5 TB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank, slots 13 - 24 are available in two-processor configuration only
- Configuration Features
- 1 x 32 GB
- RAM Supported
- 3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Storage Controller (2nd)
- SATA
- HPE Smart Array S100i SR Software
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- FlexibleLOM
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HPE 331i
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 0 (free) x FlexibleLOM - three-quarter-length, full-height (low-profile) , 1 (total) / 1 (free) x PCIe 3.0 x16 - three-quarter-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x PCIe x16 - full-height
- 1 x HPE iLO - Type A (1 in front) , 1 x HPE iLO - RJ-45 (1 rear) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 1 x VGA (1 rear)
- Included Accessories
- HPE Easy Install Rails, HPE standard heatsink, 5 x standard hot plug fans
- Cables Included
- Power cable
- AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- HPE Smart Buy
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 800 Watt
Operating System / Software
- Software
- HPE Server UEFI
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 43.46 cm
- 70.7 cm
- 4.29 cm
- 13.04 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 45 dBA
Internal Hard Drives (7)
HPE 1TB 6G SATA 7.2K 2.5IN SFF | In Stock | £406.28 |
HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD | In Stock | £500.78 |
HPE 300GB SAS 10K SFF SC DS-STOCK | In Stock | £124.49 |
HPE 300GB SAS 15K SFF SC DS-Stock | In Stock | £155.29 |
HPE 600GB SAS 10K SFF SC DS HDD | In Stock | £169.57 |
HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s | In Stock | £191.25 |
HPE 600GB SAS 15K SFF SC DS HDD | In Stock | £223.08 |
Other bundles (3)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.06 |
HPE Ethernet 1GB 4-Port 366T Adapter | In Stock | £164.89 |
