Do you need a platform purpose-built to address your HPC, virtualized, and memory-centric workloads? Building on HPE ProLiant as the intelligent foundation for hybrid cloud, The HPE ProLiant DL385 Gen10 server delivers superior performance for your needs. The HPE ProLiant DL325 delivers increased value to clients through intelligent automation, security and optimization.
- HPE ProLiant DL325 Gen10 Base - rack-mountable - EPYC 7262 3.2 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Server Scalability
- 1-way
- Processor
- 1 x AMD EPYC 7262 / 3.2 GHz (, up to 3.4 GHz, (8-core)
- Processor Socket
- Socket SP3
- Cache Memory
- 128 MB
- Cache Per Processor
- 128 MB
- RAM
- 16 GB (installed) / 1 TB (max) - DDR4 SDRAM
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.46 cm x 61.49 cm x 4.29 cm
- 10.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 1U
- Built-in Devices
- Led panel, battery
- 1-way
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- AMD EPYC 7262
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- Socket SP3
Cache Memory
- Installed Size
- 128 MB
- 128 MB
RAM
- Installed Size
- 16 GB / 1 TB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2933 MHz
- Rated Memory Speed
- 2933 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total)
- Registered, HPE SmartMemory
- RAM Supported
- PC4-20800 - 2 TB Load-Reduced , PC4-20800 - 1 TB registered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HPE 366FLR
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x FlexibleLOM - three-quarter-length, full-height (low-profile) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 (low-profile) , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
- Included Accessories
- 5 x performance hot plug fans
- AES, FIPS 140-2, Triple DES, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
Operating System / Software
- OS Certified
- CentOS, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, SuSE Linux Enterprise Server 12 SP3, Red Hat Enterprise Linux 7.4, Red Hat Enterprise Linux 7.5, VMware vSphere 6.5 (ESXi) Update 2, VMware vSphere 6.7 (ESXi)
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 43.46 cm
- 61.49 cm
- 4.29 cm
- 10.7 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
Warranty Packs (2)
HPE Installation and Startup - installation / configuration 1 incident On-Site | In Stock | £2,026.61 |
HPE Installation Service - installation / configuration | In Stock | £393.73 |
Internal Hard Drives (4)
HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD | In Stock | £500.78 |
HPE 300GB SAS 10K SFF SC DS-STOCK | In Stock | £124.49 |
HPE 300GB SAS 15K SFF SC DS-Stock | In Stock | £155.29 |
HPE 600GB SAS 10K SFF SC DS HDD | In Stock | £169.57 |
Other bundles (3)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.09 |
HPE Ethernet 1GB 4-Port Adapter | In Stock | £47.64 |
