HPE ProLiant DL325 Gen10 AMD EPYC 7251 8GB
Quicklinx: F8L2WS00 Mfr#: P04646-B21
Case Style: Rack-mountable
Processor Type: EPYC
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 8GB
£1,838.40 ex VAT
£2,206.08 inc VAT
The HPE ProLiant DL325 Gen10 Server is the secure and versatile single socket server for virtualization and I/O intensive workloads. This server delivers and exceptional balance of processor, memory and I/O for 2P performance at 1P TCO. Get the most out of your virtualized environment with this versatile server.
  • Delivering 2P Performance at 1P Economics
    HPE ProLiant DL325 Gen10 server supports industry standard technology utilizing the AMD EPYC 7000 series processor family with up to 64 cores, 12Gb SAS and HPE SmartMemory up to 2933 MT/s DDR4 memory.HPE ProLiant DL325 Gen10 server has a dense chassis that accommodates up to 10 SFF, up to 4 LFF, or up to 10 NVMe drive options as well as up to 3 PCIe 3.0 slots.The embedded SATA HPE Smart Array S100i Controller is standard while the redesigned HPE Smart Array Essentials and Performance Controllers allow you the flexibility to choose the 12 Gbps controller to optimize your environment.Options for HPE FlexibleLOM or PCIe standup adapters offer a choice of networking bandwidth (1GbE to 4x10GbE) and fabric enabling you to scale to the changing needs of your business.
  • Automation
    HPE iLO 5 monitors servers for ongoing management, service alerting, reporting and remote management to resolve issues quickly and keep your business running from anywhere in the world.HPE OneView is an automation engine that transforms compute, storage, and networking into software-defined infrastructure to automate tasks and speed business process implementations.HPE InfoSight provides built-in AI predicts problems before they happen, proactively resolves issues, and continually learns as it analyzes data-making every system smarter and more reliable.HPE iLO RESTful API feature provides iLO RESTful API extensions to Redfish allowing you to take full advantage of the wide range of value-added API features, and integrate easily with leading orchestration tools.
  • Security
    Silicon Root of Trust is an immutable fingerprint in the iLO silicon. The silicon root of trust validates the lowest level firmware to BIOS and software to ensure a known good state.Tied into the silicon root of trust is the AMD Secure Processor, a dedicated security processor embedded in the AMD EPYC system on a chip (SoC). The security processor manages secure boot, memory encryption and secure virtualization.Run Time Firmware Validation validates the iLO and UEFI/BIOS firmware at runtime. Notification and automated recovery is executed on detection of compromised firmware.If system corruption has been detected Server System Restore will automatically alert iLO Amplifier Pack to initiate and manage the system recovery process, avoiding lasting damage to your business by quickly restoring firmware to the factory settings or the last known authenticated safe setting.
  • Optimization
    HPE Right Mix Advisor provides data-driven guidance drives the ideal hybrid cloud mix for workloads allowing for intelligent planning speeding migrations from months to weeks and controlling the cost of migration.HPE GreenLake Flex Capacity provides pay-per-use IT consumption on-premises, with real-time tracking and metering of resource usage, so you have the capacity you need to deploy quickly, pay for the exact resources you consume, and avoid overprovisioning.HPE Foundation Care helps when there is a hardware or software problem offering several response levels dependent on IT and business requirements.HPE Proactive Care is an integrated set of hardware and software support including an enhanced call experience with start to finish case management helping resolve incidents quickly and keeping IT reliable and stable.HPE Financial Services helps you transform to a digital business with financing option and trade-in opportunities that align to your business goals.
HPE ProLiant DL325 Gen10 Entry - rack-mountable EPYC 7251 2.1 GHz - 8 GB - no HDD
Server - rack-mountable
Height (Rack Units)
1U
Region: Worldwide
Server Scalability
1-way
1 x AMD EPYC 7251 / 2.1 GHz (up to 2.9 GHz, (8-core)
Processor Socket
Socket SP3
Cache Memory
32 MB L3 Cache
Cache Per Processor
32 MB
RAM
8 GB (installed) / 2 TB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array E208i-a)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
1GbE
Power Redundancy
Optional
43.46 cm x 61.49 cm x 4.29 cm
10 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel, battery
Server Scalability
1-way
Hot-Swap Bays Qty
4
Region: Worldwide
Processor / Chipset
CPU
AMD EPYC 7251
Clock Speed
2.1 GHz
Max Turbo Speed
2.9 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
Socket SP3
Cache Memory
Installed Size
L3 Cache - 32 MB
Cache Per Processor
32 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, HPE SmartMemory
Configuration Features
1 x 8 GB
RAM Supported
PC4-20800 - 2 TB Load-Reduced , PC4-20800 - 1 TB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
1 (total) / 1 (free) x FlexibleLOM - three-quarter-length, full-height (low-profile) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 (low-profile) , 1 (total) / 1 (free) x microSD Card (internal)
1 x HPE iLO (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) (4 rear) , 1 x HPE iLO (1 rear) , 1 x VGA (1 rear)
HPE Easy Install Rails
AES, FIPS 140-2, Triple DES, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
500 watt
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, SuSE Linux Enterprise Server 12 SP3, Red Hat Enterprise Linux 7.4, Red Hat Enterprise Linux 7.5, VMware vSphere 6.5 (ESXi) Update 2, VMware vSphere 6.7 (ESXi)
43.46 cm
61.49 cm
4.29 cm
10 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
37 dBA
Warranty Packs (2)
F8L2 HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,999.63
F8L2 HPE Installation Service - installation / configuration In Stock £388.49
Internal Hard Drives (1)
F8L2 HPE 300GB SAS 15K SFF SC DS-Stock In Stock £456.47
Other bundles (2)
F8L2 HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack In Stock £196.94
F8L2 HP iLO Adv incl 3yr TS U E-LTU In Stock £310.83
Brand: HPE
Price Range Ex VAT: £1500+
