Are you looking for a compact 1U server that works in a variety of environments? The dense and compact HPE ProLiant DL20 Gen9 Server powered by Intel Pentium , Core i3 and E3-1200 v5/v6 processors provides a unique blend of enterprise-class capabilities at a great value-making it an ideal rack server platform for growing businesses and service providers. It offers outstanding configuration flexibility to cater to a wide variety of business requirements at an affordable price point. The DL20 Gen9 Server offers a range of HPE Qualified Options to fit most needs like affordable drives for light workloads, solid state drives for the demanding requirements, from a single non-hot plug power supply to an efficient HPE Hot Plug Redundant Power supply, from multiple storage controllers to the HPE FlexibleLOM networking cards-helping customers find the right configuration for their workloads.
Optimized Reliable Solution
The HPE ProLiant DL20 Gen9 server is a 1P 1U rack server that combines the right balance of performance, expandability, reliability and manageability for a variety of business needs.The DL20 Gen9 server combines a dense and compact form factor with redundant power supply capability which keeps your business running and provides data protection and accessibility even in the event of a power supply failure.Customers can protect against data loss and downtime with the enhanced error handing of HPE DDR4 ECC memory options while also improving workload performance and power efficiency.Trusted and proven HPE Smart Array technology provides businesses with protection for critical data through RAID mirroring and striping capability and, with FBWC up to 4 GB, captures and holds data indefinitely in the event of a power loss, equipment failure, or human error.Your business cannot afford disruptions due to downtime on your server. HPE Insight Online with HPE Insight Remote Support provides 24x7 remote monitoring with anywhere, anytime personalized access to your IT and support status to get your business up and running. -
Ease of Use for Many Environments and Workloads
The HPE ProLiant DL20 Gen9 server is a short-depth chassis of 15.05-inch providing mobility and easy deployment in a wide variety of environments.The HPE embedded management solution based on HPE iLO 4 provides simple, versatile and comprehensive tools to deploy, manage and troubleshoot servers-even for customers with limited IT resources.The ProLiant DL20 Gen9 server has the great quality and design features that are a hallmark of the ProLiant family such as tool-less access to system components and enhanced serviceability. -
Great Combination of Performance and Efficiency
The HPE ProLiant DL20 Gen9 server supports Flex LOM which enables next-generation network capability for faster data transfer.You have a wide choice of dual core and quad core Intel Pentium and Xeon E3-1200 processors with up to 64 GB of DDR4 ECC memory to handle any demands that your workload might make on the HPE ProLiant DL20 Gen9 Server.The ProLiant DL20 Gen9 server consumes up to 29% less power compared to the previous generation which combined with the efficient, redundant power supply solution provides you with an Energy Star certified power saving solution.
- HPE ProLiant DL20 Gen9 Performance - rack-mountable Xeon E3-1240V6 3.7 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Localisation
- Region: Worldwide
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1240V6 / 3.7 GHz (Quad-Core)
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HP H240 Smart Host Bus Adapter)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200 - up to
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 43.46 cm x 38.22 cm x 4.32 cm
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 1U
- Embedded Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- 1-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon E3-1240V6
- Clock Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C232
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 16 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HP H240 Smart Host Bus Adapter
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP 332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external , 4 (total) / 4 (free) x hot-swap 2.5" SFF
- Slots
- 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, low-profile , 1 (total) / 0 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x FlexibleLOM
- 1 x VGA , 2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 (2 in front) , 3 x USB 3.0 (2 rear, 1 internal)
- Included Accessories
- HPE Short Friction Rail kit
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, GB 9254, CNS 13438, K22, K24, ASHRAE Class A3
- Power supply
- Voltage Required
- Power Provided
- 290 Watt
- 80 PLUS Certification
- 80 PLUS Silver
- Efficiency
- 92%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 43.46 cm
- 38.22 cm
- 4.32 cm
- 10 °C
- 35 °C
- 8 - 90%
- Sound Emission
- 18 dBA
HPE Ethernet 1GB 4-Port Adapter | In Stock | £60.43 |
