The dense and compact HPE ProLiant DL20 server provides a unique blend of enterprise class capabilities & value. It offers outstanding configuration flexibility to cater to a wide variety of business requirements.
Compact and Simple Design for an Affordable Solution
HPE ProLiant DL20 Gen10 server is a short-depth chassis of 15.05 inch providing mobility and easy deployment in a wide variety of environments.HPE ProLiant DL20 Gen10 server has great quality and design features that are a hallmark of the HPE ProLiant family such as tool-less access to system components and enhanced serviceability.It provides affordable configuration choices along with a wide variety of HPE Qualified Options that addresses light workloads to the most demanding requirements.HPE ProLiant DL20 Gen10 server also supports low-cost Pentium and Core series processors to meet entry configuration requirements. -
Right Balance of Performance, Flexibility, Reliability, and Manageability for Growing Business Needs
You have a wide choice of dual core, quad core and hexa core Intel Pentium and Xeon E processors with up to 64 GB of DDR4 ECC memory to handle any demands that your workload might make on the HPE ProLiant DL20 Gen10 server.It offers outstanding configuration flexibility with support for up to two large form factor (LFF) or six small form factor (SFF) drives, four DDR4 UDIMMs, 290W or 500W or 800W power supplies, and a more efficient deployment of options via HPE FlexibleLOM and PCIe slots.The HPE ProLiant DL20 Gen10 server combines a dense and compact form factor with redundant power supply capability, which keeps your business running and provides data protection and accessibility even in the event of a power supply failure.Along with an embedded 2 x 1GbE, you have a choice of HPE FlexibleLOM or PCIe standup adapters that offer a choice of networking bandwidth (1GbE to 10GbE) and fabric so you can adapt and grow to changing business needs.HPE iLO5 provides a more efficient and easier server management. It enables large-scale FW deployment, improved GUI to simplify management with industry standard APIs, and easy system debug access. -
Security Innovations
Only Hewlett Packard Enterprise offers industry-standard servers, such as the HPE ProLiant DL20 Gen10 server, with major firmware anchored directly into the silicon and with security protection built in across the server life-cycle starting with silicon root of trust.Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Verification, enabled by the optional HPE iLO Advanced Premium Security Edition, the server's firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised server.Additional security options are available with Trusted Platform Module (TPM) to avoid unauthorized access to the server and store artifacts used to authenticate the server platforms, while the Intrusion Detection Kit logs and alerts when the server hood is removed for further protection. -
Industry-leading Services and Ease of Deployment
HPE ProLiant DL20 Gen10 server comes standard with a complete set of services from HPE Pointnext, delivering confidence, reducing risk, and helping customers realize agility and stability.HPE Pointnext services simplify the stages of your IT journey. Advisory and Transformation Services professionals understand customer challenges and design an ideal solution. Professional services enables rapid deployment of solutions.Services provided under Operational services include: HPE GreenLake Flex Capacity, HPE Datacenter Care - Infrastructure Automation, HPE Campus Care, HPE Proactive Services, and HPE Datacenter Care for Multi-vendor. Operational services provides the ongoing support.Hewlett Packard Enterprise IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
- HPE ProLiant DL20 Gen10 solution - rack-mountable Xeon E-2134 3.5 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Localisation
- Region: Worldwide
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E-2134 / 3.5 GHz (up to 4.5 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-21333
- Storage Controller
- RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software RAID)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200 - up to
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 43.46 cm x 38.22 cm x 4.32 cm
- 7.88 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 1U
- 1-way
- Hot-Swap Bays Qty
- 4
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon E-2134
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 4.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 16 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software RAID
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HPE 332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile (x8 mode)
- 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal)
- Included Accessories
- HPE Short Friction Rail kit
- AES, FIPS 140-2, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1, Redfish API, UEFI
- Power supply
- Power Redundancy
- Installed Qty
- 1
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Sustainability Information
- ENERGY STAR Certified
- 43.46 cm
- 38.22 cm
- 4.32 cm
- 7.88 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 27 dBA
HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack | In Stock | £209.27 |
HP iLO Adv incl 3yr TS U E-LTU | In Stock | £311.60 |
