Are you searching for a dense server with exceptional value to run on-premises and hybrid cloud solutions? The secure HPE ProLiant DL160 Gen10 server delivers the right balance of performance, storage, reliability, manageability and efficiency in a dense and compact chassis, to meet the needs of growing businesses of a diverse set of customers - from SMB to service providers running wide range of workloads.
Scalability and Efficiency in a Dense Design
The HPE ProLiant DL160 Gen10 server supports 1st and 2nd generation Intel Xeon Scalable processors, up to 26 cores and up to 150W.Deploy mid-level virtualization, IT/ web infrastructure for SMBs and small enterprises.Right balanced server to support multiple workloads. -
Agile, Secure Infrastructure Management for Accelerating IT Service Delivery
HPE iLO 5 enables the world's most secure industry standard servers with HPE silicon root of trust technology to protect your servers from attacks, detect potential intrusions and recover your essential server firmware securely.Features include iLO Security Dashboard that helps detect and address possible security vulnerabilities and Workload Performance Advisor that provides server tuning recommendations for better server performance.Millions of lines of firmware code run before the server OS boots and with Runtime Firmware Verification, enabled by HPE iLO Advanced. The server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to server and securely stores artifacts used to authenticate the server platforms while the Intrusion Detection Kit logs and alerts when the server hood is removed. -
Industry-Leading Serviceability and Simplified Deployment
HPE ProLiant DL160 Gen10 server comes with a complete set of services offered by HPE Pointnext, delivering confidence, reducing risk, and helping customers realize agility and stability.Services from HPE Pointnext simplify the stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an enhanced solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
- HPE ProLiant DL160 Gen10 Base - rack-mountable Xeon Silver 4110 2.1 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4110 / 2.1 GHz (8-core)
- Cache Memory
- 11 MB L3 Cache
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s) - PCIe 3.0 x4 (HPE Smart Array S100i)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- - up to
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.46 cm x 61.49 cm x 4.29 cm
- 10.97 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon Silver 4110
- Clock Speed
- 2.1 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C622
Cache Memory
- Installed Size
- L3 Cache - 11 MB
- 11 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 7 (empty)
- Registered
- Configuration Features
- 1 x 16 GB
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - PCIe 3.0 x4
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i
- Channel Qty
- 14
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0
- Wake on LAN (WoL), PXE support
- Bays
- 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x FlexibleLOM (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, half-height
- 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 1 x management , 4 x USB 3.0 (1 front, 2 rear, 1 internal)
- Included Accessories
- HPE Easy Install Rails
- WEEE, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 43.46 cm
- 61.49 cm
- 4.29 cm
- 10.97 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 27.8 dBA
HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack | In Stock | £196.94 |
HP iLO Adv incl 3yr TS U E-LTU | In Stock | £311.60 |
