HPE ProLiant 4GB SD Flash Media Option Kit
Quicklinx: 6N93WS00 Mfr#: 580387-B21
HP provides several high performance Flash Media kits for customers who require boot from flash solutions. Form factors include USB Key, SD Card and MicroSD Card allowing the flexibility to support VMWare Hypervisors and direct OS boot for Windows2012 Server and Linux across HP ProLiant portfolio. HP Flash Media kits optimized for VMWare Hypervisors: - HP 2GB USB Flash Media Drive Key Kit - HP 4GB SD Enterprise Performance Flash Media Kit - HP 4GB microSD Enterprise Performance Flash Media Kit - HP 8GB SD Enterprise Mainstream Flash Media Kit - HP 8GB microSD Enterprise Mainstream Flash Media Kit HP Flash Media kits optimized for Windows2012 and Linux boot: - HP 32GB SD Enterprise Mainstream Flash Media Kit - HP 32GB microSD Enterprise Mainstream Flash Media Kit.
  • Enterprise and Mainstream HP Flash Media Kits offer higher performance and better reliability
    Higher write cycles (up to 100,000 write cycles or 10 times greater than consumer products).Static and dynamic wear leveling.Error Correcting Code capability (40bits/1K).Data Retention of 1 year at the life end of the flash.Supports Intelligent Provisioning of OS (only supported for OS Boot solutions).
HPE - flash memory card - 4 GB - SD
Flash memory card
SD Memory Card
Storage Capacity
4 GB
ProLiant BL280c G6, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, BL685c G6, DL320 G6, DL360 G7, DL360e Gen8, DL370 G6, DL380 G6, DL380 G7, DL380p Gen8, DL385 G7, DL580 G7, DL585 G7, DL980 G7, ML310e Gen8, ML330 G6, ML350 G6, ML350e Gen8, ML350p Gen8, ML370 G6
Flash memory card
Storage Capacity
4 GB
SD Memory Card
HPE ProLiant BL280c G6, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, BL685c G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL360e Gen8, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350p Gen8, ML370 G6, ML370 G6 Base, ML370 G6 Entry
