HPE procurve switch vl 20port Gig-T+4 SFP module
Quicklinx: 75CBWS00 Mfr#: J9033A
Type: Modules
£776.54 ex VAT
£931.84 inc VAT
The HP vl 20p Gig-T+ 4P SFP module switch provides 20 ports of 10/100/100-T and 4 ports of SFT for use in the Switch 4200vl series.
HPE vl 20p Gig-T+ 4P SFP module switch - expansion module - Gigabit Ethernet x 20
Expansion module
Plug-in module
Ports
20.3 cm x 22.8 cm x 4.5 cm
0.69 kg
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Auxiliary Ports
4 x SFP (mini-GBIC)
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
HPE 4208-96 vl Switch
Expansion module
Plug-in module
Ports
Wired
Cabling Type
Auxiliary Ports
4 x SFP (mini-GBIC)
Data Transfer Rate
1 Gbps
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
Expansion Slots
4 (total) / 4 (free) x SFP
20 x 1000Base-T - RJ-45
Compatible Slots
1 x Expansion Slot
20.3 cm
22.8 cm
4.5 cm
0.69 kg
75CB C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
75CB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.92
75CB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.58
Type: Modules
Brand: HPE
Price Range Ex VAT: £750 - £1000
