Your basket is empty
HPE ProCurve Switch 4208vl-72GS
Quicklinx: 57KVWS00 Mfr#: J9030A
Type: Gigabit Ethernet
Ports: 68
Data Transfer Rate: 1Gbps
Managed: Yes
POE: [N/A]
£2,708.74 ex VAT
£3,250.48 inc VAT
The HP 4200 vl Switch Series provides cost-effective Layer 2 modular switching for enterprise edge deployments. This flexible modular switch supports 10/100, Gigabit Ethernet and 10GbE connectivity and basic IP routing with up to 16 static routes. An optional redundant power supply can be added for uninterrupted power. The HP 4200 vl Switch Series can be seamlessly managed with the optional HP Intelligent Management Center (IMC) Software Platform.
HPE 4208-68G-4SFP vl Switch - switch - 68 ports - Managed - rack-mountable
Switch - 68 ports - Managed
Enclosure Type
Rack-mountable 5U
Subtype
Gigabit Ethernet
Ports
68 x 10/100/1000 + 4 x SFP
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
Routing, VLAN support, auto-uplink (auto MDI/MDI-X), manageable
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
Power Redundancy
Optional
44.2 cm x 38.9 cm x 22.2 cm
14 kg
Enclosure Type
Rack-mountable 5U
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Motorola MPC8245: 330 MHz
RAM
64 MB SDRAM
Flash Memory
24 MB Flash
1 x serial (RS-232) DB-9 management , 68 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
Expansion Slots
8 (total) / 5 (free) x Expansion Slot
Installed Modules Qty (Max)
3 (installed) / 8 (max)
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
630 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, CSA 22.2 No. 950, UL 60950
44.2 cm
38.9 cm
22.2 cm
14 kg
Limited warranty - lifetime
15 - 95%
Ports: 68
Managed: Yes
POE: [N/A]
Brand: HPE
Price Range Ex VAT: 1500+
