HPE ProCurve Switch 4208vl-72GS
Quicklinx: 57KVWS00 Mfr#: J9030A
The HP 4200 vl Switch Series provides cost-effective Layer 2 modular switching for enterprise edge deployments. This flexible modular switch supports 10/100, Gigabit Ethernet and 10GbE connectivity and basic IP routing with up to 16 static routes. An optional redundant power supply can be added for uninterrupted power. The HP 4200 vl Switch Series can be seamlessly managed with the optional HP Intelligent Management Center (IMC) Software Platform.
  • Layer 2 Modular Access Switches
    The HPE 4200 vl Switch Series provides cost-effective Layer 2 modular switching for enterprise edge deployments.Basic IP routing enables automatic routing to the connected VLANs and up to 16 static routes, including one default route, in IP networks.Optional redundant power supply for uninterrupted power.10GbE modules for bandwidth demanding applications.
  • Security with Quality of Service
    The HPE 4200 vl Switch Series includes security and quality of services features such as traffic prioritization (IEEE 802.1p) which allows real-time traffic classification into eight priority levels mapped to eight queues.Flexible authentication options include 802.1X, MAC and Web Authentication modes for improved security and policy-driven application authentication.
  • Single View of the Network
    The HPE 4200 vl Switch Series can be seamlessly managed with the optional HPE Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms and events.
HPE 4208-68G-4SFP vl Switch - switch - 68 ports - Managed - rack-mountable
Switch - 68 ports - Managed
Enclosure Type
Rack-mountable 5U
Subtype
Gigabit Ethernet
Ports
68 x 10/100/1000 + 4 x SFP
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
Routing, VLAN support, auto-uplink (auto MDI/MDI-X), manageable
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
Power Redundancy
Optional
44.2 cm x 38.9 cm x 22.2 cm
14 kg
Enclosure Type
Rack-mountable 5U
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Motorola MPC8245: 330 MHz
RAM
64 MB SDRAM
Flash Memory
24 MB Flash
1 x serial (RS-232) DB-9 management , 68 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
Expansion Slots
8 (total) / 5 (free) x Expansion Slot
Installed Modules Qty (Max)
3 (installed) / 8 (max)
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
630 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, CSA 22.2 No. 950, UL 60950
44.2 cm
38.9 cm
22.2 cm
14 kg
Limited warranty - lifetime
15 - 95%
