HPE ProCurve Switch 2510-48G
Quicklinx: 57JLWS00 Mfr#: J9280A
Designed to provide essential solutions to small and medium businesses, the HP 2510 Switch Series consists of four Layer 2-managed switches that provide reliable 10/100 and 10/100/1000 connectivity. Building off of the popularity of the HP 2510-24 Switch, a 24-port 10/100 switch with two dual-personality ports, the 2510 switch series has expanded to include a higher-density HP 2510-48 Switch, with 48 10/100 ports and four Gigabit Ethernet uplinks. Additionally, the 2510-G switches add Gigabit Ethernet to the 2510 series, with the 2510G-24 and 2510G-48 switches, which are 24- and 48-port 10/100/1000 switches, each with four dual-personality ports, making them ideal for businesses that are ready to upgrade to increased network performance.
  • Quality of Service (QoS)
    IEEE 802.1p prioritization: delivers data to devices based on the priority and type of traffic.
  • Connectivity
    10/100 and 10/100/1000 connectivity: provides customers with the choice of selecting the network connectivity speed that best meets their needs, with a consistent user experience.Gigabit uplinks: E2510-24 and E2510-48 switches: the E2510-24 switch has two dual-personality ports for either 10/100/1000 or mini-GBIC connectivity; the E2510-48 switch has four Gigabit Ethernet ports, which can all be used concurrently with two 10/100/1000 ports and two open mini-GBIC slots. E2510G-24 and E2510G-48 switches: four dual-personality ports for 10/100/1000 or SFP ports for optional fiber connectivity such as Gigabit-SX, -LX, and -LH, or 100-FX.HPE Auto-MDIX: automatically adjusts for straight-through or crossover cables on all 10/100 and 10/100/1000 copper ports.
  • Resiliency and high availability
    IEEE 802.1s Multiple Spanning Tree: provides high link availability in multiple VLAN environments by allowing multiple spanning trees; provides legacy support for IEEE 802.1d and IEEE 802.1w.IEEE 802.3ad Link Aggregation Control Protocol (LACP) and HPE trunking: - E2510-24 switch supports up to two 10/100 trunks each with four links/ports plus one Gigabit Ethernet trunk. - E2510-48 switch supports up to 24 trunks with eight links/ports per trunk. - E2510-24G & E2510-48G switches support up to 24 trunks with eight links/ports per trunk.
  • Manageability
    IEEE 802.1AB Link Layer Discovery Protocol (LLDP): provides automated device discovery protocol for easy mapping by network management applications.RMON: provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events.Full-featured console: provides complete control of the switch with a familiar command-line interface (CLI).Web interface: allows configuration of the switch from any Web browser on the network.Single IP Address Management: provides single IP address management for a virtual stack of up to 16 switches.
HPE 2510-48G Switch - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 + 4 x combo SFP
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP)
44.2 cm x 32.3 cm x 4.3 cm
3.9 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
64 MB SDRAM
Flash Memory
16 MB Flash
48 x 1000Base-T RJ-45 , 1 x serial (RS-232) RJ-45 management , 4 x SFP (mini-GBIC)
Internal power supply
30 Watt
Mounting Kit
Included
FCC Class A certified, CSA, CISPR 22 Class A, CISPR 24, cUL, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC950, NOM, UL 1950, VCCI Class A ITE, EN 61000-3-3, EN55024
44.2 cm
32.3 cm
4.3 cm
3.9 kg
45 °C
