HP Modular PDU with Fixed Cord Extension Bars are optimized for use with 1U rack mount fixed rail servers. They significantly improve cable management and airflow, and provide the power distribution needed to run your rack-mounted systems.
The modular PDU with fixed cord extension bars are ideal for use with 1U rack mount servers, which are fixed in place in the rack. DL360 and DL320 servers will significantly benefit from the shorter cables, improving cable management concerns and increasing the airflow through the back of the rack. For redundant applications, two PDU sticks may be placed side by side to allow independent power sources to reach the same server.
- HPE C-13 PDU Extension Bar - power distribution strip
- Power distribution strip
- Packaged Quantity
- 2 (specifications are for single item)
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 7 x power IEC 60320 C13
- Designed For
- UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000, T1000 G3, T1500 G3, T750 G2; UPS R12000/3, R7000, R8000/3
- Packaged Quantity
- Input Connectors
- Power Output Connectors Details
- Designed For
- HP UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000, T1000 G3, T1500 G3, T750 G2 , HPE UPS R12000/3, R7000, R8000/3
