The HPE OfficeConnect 1405 is a Plug and Play unmanaged Layer 2 switch, designed for small offices. The 1405 small office switches are preconfigured for fast, easy installation, with connections using low-cost Ethernet copper cabling. They support administration-friendly features, such as auto-negotiation and automatic cable type detection (MDI/MDIX), and are FCC Class B certified and approved for both business and home office locations. They have energy-saving features, such as energy-efficient Ethernet (EEE) and idle-port power down. They are fanless for quiet and "green" operation, and are designed for high reliability, long life, low power consumption, and low total cost of ownership.
Traffic prioritization (IEEE 802.1p)
Allows real-time traffic classification, mapped to multiple hardware queues. -
Class of Service (CoS)
Prioritizes traffic by honoring Differentiated Services Code Point (DSCP). -
Auto-MDIX
Automatically adjusts for straight-through or crossover cables on all 10/100 and 10/100/1000 ports. -
Flow control
Helps ensure reliable communications during full-duplex operation. -
Comprehensive LED display with per-port indicators
Provides an at-a-glance view of status, activity, speed, and full-duplex operation.
- HPE OfficeConnect 1405 8G v3 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Switching capacity: 16 Gbps , Throughput: 11.8 Mpps , Latency (100 Mbps): 3 µs , Latency (1000Base-T): 2.6 µs
- MAC Address Table Size
- 8192 entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, full duplex capability, Layer 2 switching, auto-uplink (auto MDI/MDI-X), half duplex mode, Quality of Service (QoS), fanless, Energy Efficient Ethernet, Class of Service (CoS), DiffServ Code Point (DSCP) support, 1.5MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 15.49 cm x 9.14 cm x 3.56 cm
- 230 g
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 8192 entries
- 9216 bytes
- 8 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 4.5 Watt
- Plug and Play, UL 60950, EN55022 Class B, ICES-003 Class B, RoHS, IEC 60950-1, EN 60950-1, WEEE, CAN/CSA C22.2 No. 60950-1-03, AS/NZS CISPR 22 Class B, FCC Part 15 Class B
- 15.49 cm
- 9.14 cm
- 3.56 cm
- 230 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 15 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
