HPE NC112T PCIe Gigabit Server Ada
Quicklinx: 6426WS00 Mfr#: 503746-B21
The HP NC112T is a low-priced Gigabit Ethernet server adapter that features single-port, copper, single lane (x1) PCI Express capability, with 32KB onboard memory that provides 10/100/1000T auto-negotiated speed and duplex. It makes use of the latest Intel 82574L silicon and is suitable for both standard and low profile slots.
  • Gigabit throughput combined with legacy Ethernet support
    10/100/1000Mbps Ethernet transfer rate delivers outstanding network performance that improves response time and removes bottlenecks. Because the NC112T supports both 10Mbps Ethernet and 100Mbps Fast Ethernet in addition to Gigabit Ethernet, users are guaranteed end-to-end protocol support across their enterprise.
  • PCI Express interface
    HP was an early champion of PCI Express bus technology and has played a key role in the development and industry adoption of the PCI Express specification. The NC112T features an Intel 82574L chipset and offers a single lane (x1) PCI Express bus based on the PCIe v1.1 standard.
  • Load Balancing
    Transmit Load Balancing (TLB) and Switch-assisted Load Balancing (SLB) are two advanced features that customers can use to build a bigger pipe for improved networking bandwidth. These port bonding techniques enable users to install up to eight NC112T adapters (or a mix of other HP adapters totaling 8 ports) in a HP ProLiant server and aggregate their throughput up to a theoretical maximum of 16 Gigabits per second full-duplex transmissions.
  • Jumbo frames
    Jumbo frames (also known as extended frames) offers a 9K byte Maximum Transmission Unit (MTU), which is six times the size of traditional Ethernet frames. Like all HP ProLiant server adapters, the NC112T supports jumbo frames as a way to achieve higher throughput and better CPU utilization when deployed in a network infrastructure that supports them.
  • TCP Checksum Offload and Large Send Offload (LSO)
    These features reduce the load on the CPU to improve improved overall system response. LSO is based on both IPv4 and IPv6 and TCP Checksum Offload is IPv6 based.
HPE NC112T - network adapter - PCIe
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
13 cm x 5.6 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
1 x Intel 82574L
RAM
32 KB
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
SUSE Linux Enterprise Server, SunSoft Solaris 9, SCO OpenServer 5.0.7, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Web Edition, Microsoft Windows Server 2003 Standard Edition, Microsoft Windows Server 2003, UnixWare 7.1.3, Novell NetWare 6.5, Microsoft Windows Small Business Server 2003, Red Hat Enterprise Linux, UnixWare 7.1.4, SunSoft Solaris 10, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, SCO OpenServer 6
ProLiant DL120 G7, DL165 G7, DL360 G7, DL360p Gen8, DL370 G6, DL380 G6, DL380 G7, DL380p Gen8, DL385 G6, DL385p Gen8, DL388p Gen8, DL560 Gen8, DL580 G5, MicroServer Gen8, ML10, ML110 G7, ML310e Gen8, ML350e Gen8, ML350p Gen8, ML370 G6, SL160s G6, SL165s G7, SL230s Gen8, SL250s Gen8, SL270s Gen8
Network adapter
PCI Express x1
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, link/activity
Auto-negotiation, WOL
Processor / Memory
1 x Intel 82574L
RAM
32 KB
1 x network - RJ-45
Compatible Slots
1 x PCI Express x1
Low-profile bracket
ACPI, FCC Class B certified, UL, VCCI Class B ITE, BSMI CNS 13438 Class A, CISPR 22 Class B, EN 60950, UL 1950, VCCI-II, EN55024, EN55022 Class B, ICES-003 Class B, MIC, ACA
13 cm
5.6 cm
55 °C
10 - 95%
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL165 G7 Performance, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL370 G6 High Performance, DL370 G6 Special Server, DL380 G6, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385 G6 ICE Performance, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL388p Gen8 Base, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7 Base, DL580 G7 High Performance, DL980 G7, MicroServer, MicroServer Gen8, ML10 Entry, ML10 Special, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Special Server, ML370 G6 Special Server, SL160s G6, SL165s G7, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray , HPE StorageWorks Network Storage Gateway X3800 G2 , HPE StorageWorks Network Storage System X1400 G2, X1800, X1800 G2
