HPE MSR30-16 Router
Quicklinx: 9JXMWS00 Mfr#: JG512A
  • IEEE 802.11n
£555.56 ex VAT
£666.67 inc VAT
The HP MSR93x Router Series delivers a high-performance small-branch router providing integrated routing, switching, security, SIP, 802.11n WLAN connectivity, and 4G LTE/3G in a single unit. With its Converged Infrastructure, it enables faster time to service and enhanced performance while simplifying your network through a single management screen and zero-touch deployment. The MSR93x increases flexibility and agility, delivering extensive connectivity capabilities in a compact, fixed form factor. The MSR93x is based on open standards for seamless integration within small-branch deployment.
  • Enhanced Time to Service and Branch Performance
    The HPE MSR93x Router Series offers high performance routing with 300 kpps forwarding.Comprehensive feature set enables branch services that fit your needs, including IPv4 and IPv6 routing, MPLS, QoS, NAT, and VPN.Integrated security eases the transition to the cloud.
  • Reduces Complexity and Simplifies Your Network
    The HPE MSR93x Router Series provides a Converged Infrastructure (CI) with integrated routing/switching/security/SIP.Reduce total cost of ownership (TCO) through open standards, power and space savings, and energy-efficient hardware.A single screen with HPE Intelligent Management Center (IMC) provides an easy-to-use interface for your administrator.Zero-touch deployment makes router and VPN set up a breeze.Common OS across routers delivers increased flexibility across all environments.
  • Increased Flexibility and Agility Across Your Network
    The HPE MSR93x Router Series delivers a wide range of connectivity options, including Gigabit Ethernet, Serial, ADSL2+, G.SHDSL, and wireless.Extensive range of models and accessories enables the right design for your particular requirements.Based on open standards for ease of network integration.
  • Strengthen Branch Resiliency with Enterprise-class Features
    The HPE MSR93x Router Series supports primary and failover 4GE LTE and 3G WAN connectivity enabling service survivability.Enhanced 802.11n WLAN option provides high throughput.
HPE MSR930 - router - Wi-Fi
Router - 4-port switch (integrated)
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Performance
Throughput: up to 0.3 Mpps , Encryption throughput: up to 160 Mbps
IPv4 routing table entries: 10000 , IPv6 routing table entries: 5000 , VPN tunnels: up to 100
Network / Transport Protocol
TCP/IP, L2TP, RSVP, NTP, PPPoE
Routing Protocol
OSPF, BGP-4, IS-IS, RIP-1, RIP-2, IGMPv2, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, GRE, OSPFv3, Multiprotocol BGP, MSDP, static IPv4 routing, static IPv6 routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, Telnet, SNMP 3, HTTP, TFTP, CLI
Firewall protection, DHCP support, NAT support, VPN support, BOOTP support, ARP support, MPLS support, IGMP snooping, Syslog support, port mirroring, IPv6 support, WFQ, WRED, sFlow, TFTP support, ACL support, QoS, CAR, MLD snooping, port isolation
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.1s, IEEE 802.11n
23 cm x 16 cm x 4.36 cm
1.2 kg
Wireless, wired
Performance
Routing Protocol
Encryption Algorithm
Triple DES, MD5, AES, TLS
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.1s, IEEE 802.11n, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 61000-4-11, RoHS, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FDA, FCC CFR47 Part 15 B, EN 60825-1, AS/NZS 60950, ANSI C63.4, EN 60825-2, CAN/CSA C22.2 No. 60950-1-03, EN 61000-3-2:2006, EN 61000-3-3:1995+A1:2001+A2:2005, EN 300 386, CAN/CSA-C22.2 No. 60950-1
1 x 533 MHz
RAM
256 MB DDR SDRAM
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Antenna Qty
2
External power adapter
23 cm
16 cm
4.36 cm
1.2 kg
5 - 90% (non-condensing)
9JXM C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9JXM C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.93
9JXM C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.58
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Brand: HPE
Price Range Ex VAT: £500 - £750
