HPE Modular Smart Array 2040 SAS Dual Controller SFF Bundle
Quicklinx: CL9GWS00 Mfr#: M0T32A
Changing storage needs for server customers now requires greater levels of performance and functionality at a lower cost of ownership. The next generation HPE MSA 2040 Storage arrays raises the bar & uniquely addresses HPE ProLiant customers' shared storage and data protection needs, reduces TCO while dramatically increasing performance using technologies such as Solid State Drives, Snap and Volume copy, Replication and SEDs. The MSA 2040 Storage arrays are positioned to provide an excellent value for customers needing increasing performance to support initiatives such as consolidation and virtualization. The MSA 2040 delivers this performance by leveraging new controller architecture with a new processor, four ports with 4GB cache per controller & using drive technologies such as SSDs. The MSA 2040 Storage ships standard with 64 Snapshots and Volume Copy enabled for increased data protection and allow replication with optional Remote Snap software between arrays (FC or iSCSI only).
  • Simple: Flexible Architecture
    Choice of 8 Gb/16 Gb FC, 1 Gb/10GbE iSCSI and 12 Gb SAS to match the configuration needs of infrastructure.Deploy single or dual controllers depending on high-availability and budgetary requirements.Select disk enclosures with Large or Small Form Factor drives –choice of High-performance Solid State Drives, Enterprise-class SAS or SAS Midline drives or Self-Encrypting Drives (SED) based on application, performance and budget needs.The integrated setup and management tools for MSA are easy to manage for HPE ProLiant/BladeSystem IT managers.
  • Fast: MSA 2040 Sets New Standards for $/IOPS in Entry SAN, 3x to 4x Today's Competition
    New high-performance Converged SAN controller and SAS controller offer 4x the performance of today's other entry-level SAN arrays.4-port Converged SAN controller supporting Fibre Channel and iSCSI and a SAS Controller with 4GB Cache translating into better application response time and ability to support more virtualized environments.SSD support with integrated "wear gauge" helps improves application performance and allows customers to reduce their operating costs by reducing foot prints and power consumptions.Self-Encrypting Drives (SEDs) designed to safeguard critical personal and business information and to comply with regulatory mandates.
  • Futureproof: 2x the Bandwidth and the First Entry SAN with 16 Gb FC
    Choice of 8 Gb/16 Gb FC, 1 Gb/10GbE iSCSI and 12 Gb SAS to match the configuration needs of infrastructure.The 4th generation of MSA's unique Data-in-Place upgrades provides investment protection.Host ports upgradeable by SFPS (8 Gb/16 Gb FC) or (1 GB/10GbE iSCSI) allows customers to manage their total cost of ownership lower.
  • ENERGY STAR Certified: MSA 2040 is Now ENERGY STAR Certified
    ENERGY STAR certified power supplies will lead to energy consumption efficiencies translated into savings or regulatory rebates for customers.
HPE Modular Smart Array 2040 SAS Dual Controller SFF Bundle - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
4 TB
Max Supported Capacity
43 TB
SAS 12Gb/s
Maximum LUNs
512
6 (installed) / 24 (max)
Supported Drives
SAS-3
Storage Controller
RAID (SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 50
Storage Controller Quantity
2
Hard Drive
4 x 900 GB HDD
Hard Drive (2nd)
2 x 200 GB SSD
HP-UX, Red Hat Linux, SUSE Linux Enterprise Server, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012
AC 120/230 V - 50/60 Hz
Power Redundancy
Manufacturer Selling Program
HP Top Value Lite
44.7 cm x 49.5 cm x 8.9 cm
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
6
Supported Devices / Modules Qty
24
Supported Drives
SAS-3
Storage
4 TB
43 TB
HDD Array External Interface
SAS 12Gb/s
Maximum LUNs
512
CPU
No CPU
Storage Controller
RAID
Installed Qty
2
Interface Type
SAS 6Gb/s
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
8 GB
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
Installed Qty
2
Hard Drive
HDD
4 x 900 GB
Spindle Speed
10000 rpm
Hard Drive (2nd)
SSD
2 x 200 GB
Expansion Bays
24 (total) / 18 (free) - 2.5" SFF
2 x SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 2 x management , 2 x management - RJ-45 , 8 x SAS 12Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, GS, EN 61000-3-3, EN55022 Class A, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, FCC Part 15 A, EN55024 Class A, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A
HP Top Value Lite
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
44.7 cm
49.5 cm
8.9 cm
Limited warranty - parts - 3 years
5 °C
10 - 90% (non-condensing)
Sound Emission
55 dBA
