HPE ML370G5/DL380G5 Hot-Plug Pwr
Quicklinx: 4R2CWS00 Mfr#: 403781-001
  • High efficiency
    With efficiency up to 85.5% at 240VAC, this power supply ensures optimal performance while reducing energy consumption. Its ability to operate efficiently across a wide range of voltages makes it a versatile choice for various settings.
  • Robust power capacity
    Boasting a power capacity of 1217 VA and providing 1000 watts of power, this unit is capable of supporting demanding PC and server applications, ensuring your equipment runs smoothly without interruption.
  • Wide input voltage range
    Designed to accommodate a broad input voltage range of AC 90 - 264 V, this power supply adapts to different power environments, making it ideal for global use without the need for voltage converters.
HPE - power supply - hot-plug / redundant - 1000 Watt - 1217 VA
Power supply - hot-plug / redundant - plug-in module
1.8 kg
Input Voltage
AC 100/120/208/220/230/240 V
Power Capacity
1000 Watt / 1217 VA
19.6 cm x 42.4 cm x 18.6 cm
ProLiant DL380 G5, DL385 G5, DL385 G5p
Input Voltage
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Max Electric Current
30 A
Power Capacity
1000 Watt / 1217 VA
Efficiency
81.5% (100VAC), 82% (120VAC), 84% (208VAC), 84% (220VAC), 85% (230VAC), 85.5% (240VAC)
Power Factor (PF)
0.98
19.6 cm
42.4 cm
18.6 cm
1.8 kg
HPE ProLiant DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Availability Storage Server, DL380 G5 High Efficiency, DL380 G5 High Performance, DL380 G5 Performance, DL385 G5, DL385 G5 Base, DL385 G5 Carrier-Grade, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p, DL385 G5p Base, DL385 G5p Entry, DL385 G5p High Performance
