HPE Midline 4 TB - SATA 6Gb/s HDD
Quicklinx: DFKSWS00 Mfr#: 872491-B21
Form Factor: 3.5" LFF
Type: Hard drive
Capacity: 4TB
Spin Speed (rpm): 7200rpm
£152.94 ex VAT
£183.52 inc VAT
Do your servers need reliable, economical, high capacity Midline hard drives for your growing storage workload needs? HPE Server Midline Hard Drives deliver the highest capacity, performance and reliability to your datacenter applications. Midline hard drives allow you to store more data without sacrificing performance or reliability; they are ideal to store all your bulk storage requirements. HPE Server Midline Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server Midline Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
  • Smart carriers
    HPE Hard Drives with smart carriers are designed to provide an interface to communicate critical status and management information. System status LED icons and a spinning activity ring reflecting the data-writing process notify users of the current system status. A blue LED located behind the handle can be activated remotely to guide users to a specific drive tray, while a do-not-remove icon positioned on the tray's eject button lights up to warn users when the removal of the drive would cause data loss.
  • Helium drives
    Although hard drives are sealed, they have air inside. Air can create turbulence-induced risk vibrations which can limit the storage density of HDDs. Newer helium-filled drives virtually eliminate turbulence because helium is 1/7th as dense as air. This lower density allows the read/write mechanism to spin more easily and precisely, with less drag. Less internal turbulence means the drive platters can be closer together, allowing more platters and increasing the capacity potential in the same space. Less turbulence also means helium drives tend to use less power, and run cooler and quieter.
HPE Midline - hard drive - 4 TB - SATA 6Gb/s
Hard drive - hot-swap
4 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Digitally Signed Firmware
1-year warranty
Bundled with
HPE SmartDrive carrier
HPE D3600; Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL120 Gen9, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL360 Gen10, DL380 Gen10, DL380 Gen9, DL385 Gen10, DL388 Gen10, DL388 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML30 Gen9, ML350 Gen9; StoreEasy 1450
4 TB
3.5" LFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
Limited warranty - 1 year
HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 (3.5"), Medium Solution with HPE ProLiant DL360 Gen10 (3.5"), Small Solution with HPE ProLiant DL360 Gen10 (3.5") , HPE ProLiant DL20 Gen9 Base (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL20 Gen9 Solution (3.5"), DL20 Gen9 Special Server (3.5"), DL360 Gen10 (3.5"), DL360 Gen10 Base (3.5"), DL360 Gen10 Compute Server for Cohesity DataPlatform (3.5"), DL360 Gen10 Entry (3.5"), DL360 Gen10 High Performance (3.5"), DL360 Gen10 Low (3.5"), DL360 Gen10 Network Choice (3.5"), DL360 Gen10 Performance (3.5"), DL360 Gen10 Performance for Cohesity DataPlatform (3.5"), DL360 Gen10 Remote Office Branch Office Server for Cohesity DataPlatform (3.5"), DL360 Gen10 Server for CTERA (3.5"), DL360 Gen10 SMB (3.5"), DL360 Gen10 SMB Network Choice (3.5"), DL360 Gen10 Solution (3.5"), DL380 Gen10 (3.5"), DL380 Gen10 All Flash Server for Datera (3.5"), DL380 Gen10 Base (3.5"), DL380 Gen10 Entry (3.5"), DL380 Gen10 Entry SMB (3.5"), DL380 Gen10 for Cohesity DataPlatform (3.5"), DL380 Gen10 for SAP HANA Compute Block (3.5"), DL380 Gen10 High Performance (3.5"), DL380 Gen10 Hybrid Server for Datera (3.5"), DL380 Gen10 Network Choice (3.5"), DL380 Gen10 Network Choice for CTERA (3.5"), DL380 Gen10 Network Choice for SAP HANA Compute Block (3.5"), DL380 Gen10 Performance (3.5"), DL380 Gen10 Server for CTERA (3.5"), DL380 Gen10 SMB (3.5"), DL380 Gen10 SMB Networking Choice (3.5"), DL380 Gen10 Solution (3.5"), DL380 Gen9 Scale-up SAP HANA Tailored Datacenter Integration Compute Block (3.5"), DL380 Gen9 Special (3.5"), DL385 Gen10 (3.5"), DL385 Gen10 Base (3.5"), DL385 Gen10 Entry (3.5"), DL385 Gen10 High-Performance (3.5"), DL385 Gen10 Performance (3.5"), DL385 Gen10 SMB (3.5"), DL385 Gen10 Solution (3.5"), DL388 Gen10 (3.5"), DL388 Gen9 Base (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Entry (3.5"), ML30 Gen9 Performance (3.5"), ML30 Gen9 Solution (3.5")
Type: Hard drive
Capacity: 4TB
Brand: HPE
Stock Status: In stock
