Are you a small office, home office, or small business that needs a compact affordable entry level server? The HPE ProLiant MicroServer Gen10 delivers an affordable compact entry level server specifically designed for small offices, home offices, or small business environments. This compact and easy to use server can be placed almost anywhere. Simple access to hard drives, memory and PCIe slots allow easy management, installation and upgrades. HPE MicroServer Gen10 is available with ClearOS Software from HPE delivering an intuitive Web based GUI and application marketplace that is pre-loaded on your hard drive, making it ready to use right out of the box. It utilizes the AMD accelerated processing unit (APU) with graphics cores embedded to improve graphic software performance without installing an additional PCIe graphics adapter.
Be Productive and Customize With ClearOS Software from HPE
The HPE ProLiant MicroServer Gen10 can be configured with ClearOS Software from HPE, an operating system with an intuitive Web based GUI and application marketplace that can be factory pre-loaded for your convenience.The ClearOS Software from HPE is a no cost operating system and you decide what applications you want to configure while only paying for the applications and support you require. -
Unique Server Design with Worry-free Serviceability
The HPE ProLiant MicroServer Gen10 is available with easy access to hard drives, memory, and PCIe slots for simple installation or upgrade.Compact, easy to use and can be placed in almost any location with its compact design. -
Graphic Performance
HPE ProLiant MicroServer Gen10 supports the AMD accelerated processing unit (APU) with the graphics core embedded to aid customers with graphics related workloads without installing an additional graphic card.Dual display ports capable of 4K resolution video display for increased flexibility.AMD Radeon Pro WX 2100 boosts up your graphics experience by offering the new generation Graphics Core Next (GCN) GPU architecture, OpenCL 2.0 support, three 4K res. displays at 60 Hz and many more. Find out full features at: https://pro.radeon.com/en-us/product/wx-series/radeon-pro-wx-2100/.
- HPE ProLiant MicroServer Gen10 Performance - ultra micro tower - Opteron X3421 2.1 GHz - 8 GB - no HDD
- Server - ultra micro tower
- Localisation
- Region: EMEA
- Server Scalability
- 1-way
- Processor
- 1 x AMD Opteron X3421 / 2.1 GHz (, up to 3.4 GHz, (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - ECC - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s) (Marvell 88SE9230)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 23 cm x 25.4 cm x 23.5 cm
- 6.5 kg
- Limited warranty - parts and labour - 1 year - on-site
- Server
- Product Form Factor
- Ultra micro tower
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Localisation
- Region: EMEA
Processor / Chipset
- CPU
- AMD Opteron X3421
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- No HDD
Storage Controller
- SATA
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- Marvell 88SE9230
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x internal 3.5" LFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile (open ended) , 1 (total) / 1 (free) x PCIe 3.0 x4 - low-profile (x1 mode, open ended)
- 1 x VGA , 3 x USB 2.0 (2 rear, 1 internal) , 2 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (2 front, 2 rear) , 2 x DisplayPort
- EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EMC, FCC CFR47 Part 15, ACPI 5.0, GB 9254, CNS 13438, K24, CISPR 32, EN 55032
- Power supply
- Voltage Required
- Power Provided
- 200 Watt
Operating System / Software
- OS Certified
- Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, ClearOS, Red Hat Enterprise Linux 7.4
- 23 cm
- 25.4 cm
- 23.5 cm
- 6.5 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
