HPE LTO4 Ultr 1760 SCSI Ext Tape
Quicklinx: 5BZGWS00 Mfr#: EH922A
The HP StorageWorks Ultrium 1760 Tape Drive is HP's fourth-generation of LTO tape drive technology capable of storing up to 1.6TB per cartridge in under 3 hours. HP Ultrium half-height drives are designed for server customers in direct attached storage (DAS) environments where hard disk and system bottlenecks can impede data transfer rates. To further protect the most sensitive data, AES 256-bit hardware data encryption provides easy-to-enable security to prevent unauthorized access of tape cartridges. By using LTO-4 hardware data encryption, not only is data fully capable of being compressed therefore maximizing capacity, encrypted backups are completed without a loss in performance. Capable of data transfer rates up to 160MB/sec, HP's exclusive Data Rate Matching feature further optimizes performance by matching speed of host to keep drives streaming and enabling the fastest performance of any tape drive in the industry. The Ultrium 1760 provides investment protection with full read and write support with LTO-3 media, and the ability to read LTO-2 cartridge. By doubling the capacity of previous generation Ultrium drives, HP customers now require fewer data cartridges to meet their storage needs, significantly reducing their IT costs and increasing their ROI.
HPE StorageWorks Ultrium 1760 - tape drive - LTO Ultrium - SCSI
Tape drive
Recording Standard
LTO Ultrium 4
Enclosure Type
External
Interface Type
SCSI LVD
22.3 cm x 29.5 cm x 7.7 cm
4.7 kg
Storage Removable
LTO Ultrium
Storage Removable Capacity
800 GB (native) / 1.6 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 3, Ultrium 4
Data Transfer Rate (native)
80 MBps (288 GBph)
Data Transfer Rate (compressed)
160 MBps (576 GBph)
IBM AIX, SunSoft Solaris, HP-UX, Novell NetWare, Red Hat Linux, Microsoft Windows, UnitedLinux
Microsoft Certification
Compatible with Windows 7
StorageWorks D2D110 Backup System, D2D120 Backup System, D2D130 Backup System
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 4
Enclosure Type
External
Interface Type
SCSI LVD
22.3 cm
29.5 cm
7.7 cm
4.7 kg
Storage Removable
LTO Ultrium
Recording Standard
80 MBps (288 GBph)
160 MBps (576 GBph)
Average Seek / Access Time
64 sec
Buffer Size
128 MB
1 x Ultra320 SCSI LVD - 68 pin HD D-Sub (HD-68)
Media Included Qty
1
1 x SCSI cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
Power adapter
13 Watt
Software Included
Drivers & Utilities, HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
10 °C
20 - 80%
HPE StorageWorks D2D110 Backup System, D2D120 Backup System, D2D130 Backup System
