HPE LTO-7 Ultrium 15000 Ext Tape Drive
Quicklinx: CGK5WS00 Mfr#: BB874A
Type: Tape drive
Controller Type: None
£4,445.43 ex VAT
£5,334.51 inc VAT
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
  • Outstanding Capacity, Performance, Monitoring, Encryption, and File Sharing with LTFS
    HPE Storage LTO Ultrium Tape Drives provide up to 45 TB of compressed capacity on a single cartridge.LTFS allows customers to store data in an open format making the tape self-describing and file-based.Enables even the tightest backup window to be met with higher quality performance.Provides one of the highest levels of security with encryption, ensuring strong backup data privacy to protect confidential information, and addressing compliance quickly and with fewer cartridges.
  • Reliable, Well Connected, and Compatible
    HPE Storage LTO Ultrium Tape Drives near continuously adjust their speed to keep the drives streaming, maximizing performance, and reducing start-stop cycles, which significantly increases the reliability of Hewlett Packard Enterprise drives and media.SAS models are qualified on HPE and non-HPE servers; including popular platforms from vendors such as IBM and Quantum.  See HPE Storage Single Point of Connectivity Knowledge.Extensive list of supported backup and archiving software applications from Veeam, Commvault, Veritas, Dell EMC, IBM, and many more.
  • Complete Solution Straight Out of the Box
    HPE Storage LTO Ultrium Tape Drives provides HPE LTO media, cables, and user guides.For IT organizations with stringent, long-term data retention requirements, WORM data protection capability offers a simple and reliable method for archiving records allowing customers to affordably meet the toughest industry compliance regulations.
HPE StoreEver LTO-7 Ultrium 15000 - tape drive - LTO Ultrium - SAS-2
Tape drive
Recording Standard
LTO Ultrium 7
Enclosure Type
External
Interface Type
SAS-2
Key Features
Encryption
22.3 cm x 29.5 cm x 7.7 cm
4.65 kg
Storage Removable
LTO Ultrium
Storage Removable Capacity
6 TB (native) / 15 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 6, Ultrium 7
Data Transfer Rate (native)
300 MBps (1.08 TBph)
Data Transfer Rate (compressed)
750 MBps (2.7 TBph)
HP Tru64 UNIX, HP-UX, IBM AIX, Microsoft Windows, Red Hat Linux, SunSoft Solaris, SuSe Linux
3-year warranty
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 7
Enclosure Type
External
Interface Type
SAS-2
Key Features
Encryption
22.3 cm
29.5 cm
7.7 cm
4.65 kg
Storage Removable
LTO Ultrium
Recording Standard
750 MBps (2.7 TBph)
Average Seek / Access Time
12 sec
Buffer Size
1024 MB
1 x SAS 6Gb/s - 26 pin 4x Mini SAS (SFF-8088)
MTBF
250,000 hour(s)
BSMI, CAN/CSA C22.2 No. 60950, cCSAus, C-Tick, EN 60950, FCC CFR47 Part 15, IEC 60950, NOM, RRL, TUV, VCCI
Software Included
Drivers & Utilities
Limited warranty - parts - 3 years - response time: next day , Technical support - phone consulting - 3 years - availability: 9 hours a day / Monday-Friday
10 °C
20 - 80% (non-condensing)
CGK5 HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
CGK5 HPE LTO-6 Ultrium 6.25TB RW Data Tape In Stock £33.18
Type: Tape drive
Brand: HPE
Price Range Ex VAT: £1500+
