HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
Outstanding Capacity, Performance, Monitoring, Encryption, and File Sharing with LTFS
HPE Storage LTO Ultrium Tape Drives provide up to 45 TB of compressed capacity on a single cartridge.LTFS allows customers to store data in an open format making the tape self-describing and file-based.Enables even the tightest backup window to be met with higher quality performance.Provides one of the highest levels of security with encryption, ensuring strong backup data privacy to protect confidential information, and addressing compliance quickly and with fewer cartridges. -
Reliable, Well Connected, and Compatible
HPE Storage LTO Ultrium Tape Drives near continuously adjust their speed to keep the drives streaming, maximizing performance, and reducing start-stop cycles, which significantly increases the reliability of Hewlett Packard Enterprise drives and media.SAS models are qualified on HPE and non-HPE servers; including popular platforms from vendors such as IBM and Quantum. See HPE Storage Single Point of Connectivity Knowledge.Extensive list of supported backup and archiving software applications from Veeam, Commvault, Veritas, Dell EMC, IBM, and many more. -
Complete Solution Straight Out of the Box
HPE Storage LTO Ultrium Tape Drives provides HPE LTO media, cables, and user guides.For IT organizations with stringent, long-term data retention requirements, WORM data protection capability offers a simple and reliable method for archiving records allowing customers to affordably meet the toughest industry compliance regulations.
- HPE StoreEver 6250 - tape drive - LTO Ultrium - SAS-2
- Tape drive
- Recording Standard
- LTO Ultrium 6
- Enclosure Type
- Internal
- Interface Type
- SAS-2
- Key Features
- Encryption
- 14.5 cm x 20.6 cm x 4.1 cm
- 1.45 kg
- Storage Removable
- LTO Ultrium - 5.25" x 1/2H
- Storage Removable Capacity
- 2.5 TB (native) / 6.25 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 6, Ultrium 5
- Data Transfer Rate (native)
- 160 MBps (576 GBph)
- Data Transfer Rate (compressed)
- 400 MBps (1440 GBph)
- Designed For
- ProLiant DL320e Gen8, DL360 G7, DL360e Gen8, DL360p Gen8, DL380 G7, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL270s Gen8
- Tape drive - LTO Ultrium
- LTO Ultrium 6
- Enclosure Type
- Internal
- Interface Type
- SAS-2
- Key Features
- Encryption
- 14.5 cm
- 20.6 cm
- 4.1 cm
- 1.45 kg
Storage Removable
- Capacity
- Ultrium 5, Ultrium 6
- Average Seek / Access Time
- 50 sec
- Buffer Size
- 512 MB
- 1 x SAS-2 - 29 pin internal SAS (SFF-8482)
- Compatible Bay
- 1 x front accessible - 5.25" x 1/2H
- Media Included Qty
- 1
- Cables Included
- 1 x SAS cable
- MTBF
- 250,000 hour(s)
- TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, RoHS, FCC CFR47 Part 15, cCSAus
- Software Included
- HP Library and Tape Tools
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
- Designed For
- HPE ProLiant DL320e Gen8 Entry, DL360 G7, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 G7, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray
HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge | In Stock | £35.59 |
HPE Ultrium Data Cart LTO 5 | In Stock | £27.18 |
HPE LTO-6 Ultrium 6.25TB RW Data Tape | In Stock | £33.41 |
HPE 2.0m External Mini SAS High Density to Mini SAS Cable | In Stock | £71.53 |
