HPE LTO-4 Ultrium 1.6 TB WORM Custom Labelled Data Cart 20 pk
Quicklinx: 7DSSWS00 Mfr#: C7974WL
Type: LTO Ultrium WORM
Native Capacity: 800GB
£744.01 ex VAT
£892.81 inc VAT
With HP Custom Labeled Media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. For no extra charge, cartridges can be supplied with barcode labels bearing your own specified sequences. HP rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HP Automation Group to evaluate and warrant the performance of its labels. These labels are professionally applied in a clean environment to ensure 100% readability accurate storage and retrieval in busy, automated tape libraries. Custom labeled cartridges ensure 100% label readability and can be ordered online in packs of 20. For those customers who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the customized label and offers tracking, audit and security advantages for those with IT asset tracking systems.
  • Highest Capacity and Performance of any Comparable Tape Technology
    HPE LTO-8 Ultrium can write or read data at a blistering 2.7 TB/hour, storing, encrypting and protecting up to 30 TB on a single cartridge, making it ideal for large-scale, 24 x 7, mission-critical IT environments (assumes 2.5:1 compression).An 85% increase in the number of tracks and a 8% increase in bit density has permitted an increase in capacity from 15 TB for LTO-7 to 30 TB to LTO-8: from 3,584 tracks for LTO-6 to 6,656 tracks for 8th generation HPE LTO-8 Ultrium 30 TB cartridges (assuming 2.5:1 compression).HPE LTO Ultrium cartridge memory chip delivers faster access time and enhanced media monitoring.First time restore ensured with fewer media failures and disrupted backups, regardless of duty cycle or environmental conditions.
  • Ultra-reliable
    Tape is more reliable than Enterprise SATA disk. With a BER of 1x10 to the power of 19 for LTO-8 versus 1x10 to the power of 15 for Enterprise SATA HDD's. That's a difference in reliability of four orders of magnitude – e.g. tape is 10,000 times more reliable than Enterprise SATA HDD.Estimated data loss over 10 years for 1 Exabyte archive is 1.1 Petabytes for HDD compared to only 7.4 Terabytes for tape.Superior 'smart grabber' mechanism and mechanical interlock to prevent the leader pin from being pulled inside the tape housing. Sensors detect proper connection and prevent leader loss that would ruin the tape. Simplified tape path to reduce wear, tear & build-up of debris (important in automation).HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing) go far beyond what is required for the LTO Ultrium logo.This ensures maximum reliability for restoring your data.HPE warrants LTO Ultrium cartridges for up to 30 years archival life. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving.
  • Secure
    Write-Once-Read-Many (WORM) version provides tamper-proof, compliant data storage.Data encryption for enhanced data security on HPE LTO-4, LTO-5, LTO-6, LTO-7 and LTO-8 Ultrium. Compliance with FIPS 140-2 level 1 security standards.
  • Value for money
    Standardizing on HPE LTO Ultrium delivers the capacity to meet shrinking backup windows, industry-standard, AES 256-bit encryption (IEEE1619.1), and interchangeable RW or WORM media; without extra space or IT resource overhead.Open standard technology ensures compatibility across product generations and gives you more choice. Cartridges are available as Custom Labeled, Non-Custom Labeled (both Custom and Non Custom include RFID options for some formats) and non-labeled versions.
HPE Ultrium WORM Custom Labeled Data Cartridge - LTO Ultrium WORM 4 x 20 - 800 GB - storage media
Storage media - LTO Ultrium WORM
Tape Cartridge
Ultrium 4
Media Included Qty
20
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Cartridge Labeling
Labeled
Metal Particle (MP)
HPE MSL2024, MSL4048; 1/8 G2 Tape Autoloader; StorageWorks MSL2024, MSL4048, MSL6030, MSL6060, MSL8096, SAS Rack-Mount Kit, Ultrium 1840; StorageWorks Enterprise Modular Library E-Series; StorageWorks Ultrium 1840; StoreEver Ultrium 1840
LTO Ultrium WORM
Tape Cartridge
Ultrium 4
Media Included Qty
20
Cartridge Labeling
Labeled
Media
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
20 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE StorageWorks MSL2024 Ultrium 1840, MSL4048 Ultrium 1840, MSL6030 Ultrium 1840, MSL6060 Ultrium 1840, MSL8096 Ultrium 1840, SAS Rack-Mount Kit, Ultrium 1840 Drive Upgrade Kit , HPE StorageWorks Enterprise Modular Library E-Series , HPE StorageWorks Ultrium 1840, 1840 Array Module, 1840 FC Drive Kit , HPE StoreEver Ultrium 1840 Drive Upgrade Kit
7DSS HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
7DSS HPE Ultrium Data Cart LTO 5 In Stock £23.43
7DSS HPE Ultrium RW Data Cartridge LTO Ultrium 7 6TB 15TB In Stock £51.30
Brand: HPE
Price Range Ex VAT: £500 - £750
