HP Internal USB port kit provides internal USB A-type receptacle for internal USB device or USB cable attach. It connects to motherboard header and mechanical tie down connects to chassis.
- HP Internal USB Port Kit - USB cable - USB
- USB cable
- Connector
- 4 pin USB Type A - female
- Designed For
- Workstation xw4550, xw4600, xw6600, xw8600, xw9400, Z2 G4, z200, z210, Z220, Z230, Z240, Z4 G4, z400, Z420, Z440, Z6 G4, z600, Z620, Z640, z800, Z820, Z840; ZCentral 4R
- USB cable
- Connector
- Designed For
- HP Workstation xw4550, xw4600, xw6600, xw8600, xw9400, Z2 G4, z200, z210, Z220, Z230, Z240, Z4 G4, z400, Z420, Z440, Z6 G4, z600, Z620, Z640, z800, Z820, Z840 , HP ZCentral 4R
