HPE HP V1905-8-POE SWITCH
Quicklinx: 74JZWS00 Mfr#: JD877A
HP 1905 Switch Series devices are smart-managed fixed-configuration Fast Ethernet Layer 2 switches designed for small businesses looking for key features in an easy-to-administer, low-cost solution. Series models include: 24- and 48-port non-PoE switches, 8- and 24-port PoE Fast Ethernet switches. These smart-managed switches come preconfigured for fast and easy installation, yet allow network operation to be enhanced using an intuitive Web-based management interface. Advanced security and quality-of-service features create a voice-ready network. HP 1905 series switches are solidly built for business operation, and are designed for high reliability, long life, low power consumption, and low total cost of ownership. The HP 1905 switches come with a 3-year warranty, covering unit, fans, and power adapters or power supplies.
  • Quality of Service (QoS)
    Traffic prioritization (IEEE 802.1p): allows real-time traffic classification mapped to four hardware queues per port.
  • Management
    Simple Web management: easy device management even by nontechnical users enabled by intuitive Web GUI.Secure web GUI: provides a secure, easy-to-use graphical interface for configuring the module via HTTPS.SNMPv1, v2c: devices can be discovered and monitored from an SNMP management station.Port mirroring: allows traffic to be mirrored on any port or a network analyzer to assist with diagnostics or detecting network attacks.IEEE 802.1AB Link Layer Discovery Protocol (LLDP): automated device discovery protocol for easy mapping by network management applications.
  • Connectivity
    Auto-MDIX: automatically adjusts for straight-through or crossover cables on all ports.Front-panel LEDs: provide an at-a-glance view of status, activity, speed, and full-duplex operation.Flow control: helps ensure reliable communications during full-duplex operation.Small Form-Factor Pluggable (SFP) slots: allow for fiber connectivity.Cable diagnostics: remotely detect cable issues using a browser-based tool.
HPE 1905-8-PoE Switch - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 1 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Routing Protocol
IGMP
Remote Management Protocol
RMON 2, SNMP, HTTP
Flow control, Layer 2 switching, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, manageable, STP support, RSTP support, ACL support, QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1ab (LLDP)
33 cm x 20.3 cm x 4.3 cm
2 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Routing Protocol
IGMP
RMON 2, SNMP, HTTP
Encryption Algorithm
SSL
Authentication Method
RADIUS
1: 133 MHz
RAM
32 MB SDRAM
Flash Memory
4 MB Flash
8 x 100Base-TX RJ-45 PoE , 1 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 1 x SFP (mini-GBIC)
Rack Mounting Kit
Included
VCCI, CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, UL 60950, ICES-003 Class A, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC Part 15 A
33 cm
20.3 cm
4.3 cm
2 kg
45 °C
10 - 90%
