HPE HP Ultrium 4 RW Bar Code Label Pack - Bar code labels
Quicklinx: 532HWS00 Mfr#: Q2009A
11 in stock
£112.51 ex VAT
£135.01 inc VAT
HPE LTO Ultrium, Super DLT and DLTtape IV Bar Code Label Packs provide an easy-to-use solution to the aggravation of bar coding. Under constant pressure to deliver quality of service with limited resources, the last thing IT managers should be worrying about is why their in-house bar code labels aren't working properly or whose turn it is to operate (or run) the departmental label printer. Each HPE label pack of consecutively numbered bar codes contains 100 data labels and 10 cleaning cartridge labels. No two pack sequences are ever identical to avoid data integrity issues in archives. HPE Bar Code Label Packs will be available from most resellers that stock HPE brand media. Finally, HPE Bar Code Label Packs have been fully tested to guarantee performance in demanding automation environments, so unlike cheaper alternatives, users can be certain that their backups will never be disrupted by bar code quality issues.
  • Saves Time, Money and Mistakes
    Allows staff to focus on more important tasks.Cost effective bar code labels.HPE approved labels for maximum reliability.Simple to apply to all cartridges.
HPE Ultrium 4 RW Bar Code Label Pack - bar code labels
Bar code labels
Package Content
10 labels for cleaning cartridges, 100 labels for data cartridges
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760; 1/8 G2 Tape Autoloader Ultrium 1760; LTO-4 Ultrium 1760 SAS Drive Upgrade Kit, 1760 SCSI Drive Upgrade Kit; StoreEver Ultrium 1840 Drive Upgrade Kit
Bar code labels
Package Content
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE LTO-4 Ultrium 1760 SAS Drive Upgrade Kit, 1760 SCSI Drive Upgrade Kit , HPE StoreEver Ultrium 1840 Drive Upgrade Kit
Brand: HPE
Price Range Ex VAT: 100 - 150
