HPE HP TV Ultrium 920 SAS TV Drive - Includes 4 extra
Quicklinx: 6320WS00 Mfr#: AJ760BT
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
  • Outstanding Capacity and Performance, Monitoring Capabilities, Hardware Encryption & StoreOpen/LTFS
    HPE StoreEver LTO Ultrium Tape Drives provide up to 30TB of compressed capacity on a single cartridge.HPE StoreOpen Standalone and Linear Tape File System (LTFS) allows customers to store data in an open format making the tape self-describing and file-based.Enables even the tightest backup window to be met with unprecedented performance.Provides highest level of security with encryption for strong backup data privacy to secure confidential information and address compliance quickly and with fewer cartridges.
  • Reliable, Well Connected and Compatible
    Allows the tape drive to continuously adjust the speed of the drive to keep drives streaming to maximize performance and reduce start/stops which significantly increase reliability of HPE drives and media.SAS models qualified on HPE and non-HPE servers; including popular platforms from vendors such as Dell, IBM, and Sun. See DAPR compatibility matrix on the right rail for more information.Extensive list of supported backup and archiving software applications from HPE, CA, VERITAS, Legato, Tivoli, and many more.Design leveraged from previous HPE LTO tape drives to deliver confident backups at high duty cycles.
  • Complete Solution Straight out of the Box
    Provides HPE LTO media, cables, user guides and a download flyer for the fully functional 60-day trial of Veritas Backup Exec. Customers can receive a 50% discount off Veritas MSRP.For IT organizations with stringent, long-term data retention requirements, WORM data protection capability offers a simple and secure method for archiving records allowing customers to affordably meet the toughest industry compliance regulations.
HPE StorageWorks Ultrium 920 - tape drive - LTO Ultrium - SAS
Tape drive
Recording Standard
LTO Ultrium 3
Enclosure Type
Internal
Interface Type
SAS
14.5 cm x 20.6 cm x 4.1 cm
1.5 kg
Carbonite
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
400 GB (native) / 800 GB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 2, Ultrium 3
Data Transfer Rate (native)
60 MBps (216 GBph)
Data Transfer Rate (compressed)
120 MBps (432 GBph)
IBM AIX, SunSoft Solaris, HP-UX, Novell NetWare, Red Hat Linux, Microsoft Windows, UnitedLinux
Microsoft Certification
Compatible with Windows 7
Pricing Type
Promo
3-year warranty
Workstation xw4600, xw6600, xw8600, xw9400, z400, z600, z800; ProLiant DL370 G6, DL580 G5, ML110 G4, ML110 G5, ML110 G6, ML110 G7, ML115, ML115 G1, ML115 G5, ML150 G5, ML150 G6, ML310 G4, ML310 G5, ML310 G5p, ML330 G6, ML350 G5, ML350 G6, ML370 G5, ML370 G6; StorageWorks Rack-Mount Kit Ultrium 1760
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 3
Enclosure Type
Internal
Interface Type
SAS
Enclosure Colour
Carbonite
14.5 cm
20.6 cm
4.1 cm
1.5 kg
Storage Removable
Recording Standard
60 MBps (216 GBph)
120 MBps (432 GBph)
Average Seek / Access Time
64 sec
Buffer Size
64 MB
1 x SAS
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
5
1 x SAS cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
Pricing Type
Promo
Software Included
Drivers & Utilities, HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
Limited warranty - 3 years
10 °C
20 - 80%
HP Workstation xw4600, xw6600, xw8600, xw9400, z400, z600, z800 , HPE ProLiant DL370 G6 Base, DL370 G6 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, ML110 G4, ML110 G5, ML110 G5 1TB Storage Server, ML110 G5 2TB Storage Server, ML110 G5 320GB Storage Server, ML110 G5 584GB Storage Server, ML110 G6, ML110 G7, ML115, ML115 G1, ML115 G5, ML150 G3, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G3, ML310 G4, ML310 G4 1TB Storage Server, ML310 G4 2TB Storage Server, ML310 G4 3TB Storage Server, ML310 G4 584 GB SAS Storage, ML310 G4 640 GB Storage Server, ML310 G5, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G4, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G4, ML370 G4 High Performance, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive
6320 HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
