HPE HP RACK 10622 G2 (22U) SHOCK PALLET
Quicklinx: 88SHWS00 Mfr#: AF022A
HP set the standard for performance and value in the enterprise with the 10000 G2 Series Rack family. This enterprise-class rack combines unparalleled structural integrity, cooling, and cable management; ease of use capabilities and a wide choice of rack, power and switching options to deliver a best in class product. The new rack is designated as HP's universal rack, ideal for all HP rack mounted server and storage products, complementing and protecting your investment in technology. Specifically designed to ensure outstanding cooling and cable management, the 10000 G2 Series Rack is the best choice for enterprise racks.
  • Design, Flexibility and Efficiency
    Combines a greater room inside the rack with your choice of heights in 47U, 42U, 36U or 22U and 600mm width and a 42U rack in 800mm width. Universally designed to support all HPE rack mount servers, storage and switches.Updated to include an improved door design, lighter weight side panels (sold separately), front and rear handles and lock bar for security, and new regular and heavy duty stabilization feet for 600m and 800m units.Use Rack Builder Online to configure HPE ProLiant, StorageWorks, power and networking equipment and options for the perfect fit in each HPE 10000 G2 Series Rack. Make sure you have all the options you need for your data center build out by adding in pieces that may have been overlooked.Customize each rack badge with your corporate logo for a consistent IT image or label them for easier rack identification. A blank badge ships in the hardware bag of each 10000 series rack.Receive your HPE 10000 G2 Series Rack fully loaded and ready for instant deployment when shipped on an optional shock pallet. Customers can receive their equipment preinstalled within the rack with cables already dressed neatly within the rack - saving valuable set up and unpacking time.
HPE Rack 10622 G2 Shock Pallet - rack - 22U
Rack
Carbon, metallic graphite
Rack Size
19"
Height (Rack Units)
22U
Product Material
Metal
3-year warranty
ProLiant BL25p G2, BL45p G2, DL120 G6, DL320, DL320 G5p, DL320 G6, DL360 G6, DL360p Gen8, DL365, DL365 G5, DL370 G6, DL380 G6, DL385 G2, DL385 G5, DL385 G5p, DL585 G2, DL785 G5, ML310 G4, ML350 G5, ML350 G6, ML370 G6, SL170z G6, SL2x170z G6; StorageWorks MSL8096; StorageWorks 1/8 G2 Tape Autoloader
Rack
Product Material
Metal
Rack Size
19"
Height (Rack Units)
22U
RoHS
Limited warranty: parts - 3 years
HPE ProLiant BL20p G3, BL20p G4, BL25p, BL25p G2, BL45p G2, DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL320s, DL360 G5, DL360 G5 Entry, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL580 G4 High Performance, DL585 G2 Storage Server, DL785 G5, ML310 G4 1TB Storage Server, ML310 G4 2TB Storage Server, ML310 G4 3TB Storage Server, ML310 G4 584 GB SAS Storage, ML310 G4 640 GB Storage Server, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL170z G6, SL2x170z G6 , HPE StorageWorks MSL2024 Ultrium 448, MSL2024 Ultrium 920, MSL2024 Ultrium 960, MSL8096 , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 232, Ultrium 448, Ultrium 920 , HPE StorageWorks 1/8 Tape Autoloader DLT VS80, SDLT 320, Ultrium 230, Ultrium 232, Ultrium 448, Ultrium 460, Ultrium 960
