HPE HP Quadro NVS 300 512MB DDR3 PCI-E DV
Quicklinx: 7LW6WS00 Mfr#: XP612AA
  • DisplayPort
The NVIDIA NVS 300 high resolution, multi-display business graphics solution, designed for small and standard form factor systems, delivers reliable hardware and software for a stable business environment. Tested on leading business applications, NVIDIA NVS 300 is capable of driving two VGA, single link DVI, DisplayPort or HMDI displays. With NVIDIA Mosaic and nView technologies built in, you can span and efficiently manage your entire Windows desktop across multiple displays.
  • Intelligent Power Management
    NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability.
  • NVIDIA CUDA
    CUDA's parallel computing architecture enables dramatic increases in computing performance by harnessing the power of the GPU (graphics processing unit). NVS 300 contains 16 CUDA parallel computing cores compatible with all CUDA accelerated applications.
  • Ultimate image quality
    NVIDIA NVS graphics product delivers the industry's good image quality, sharpness and pixel tracking for both analog and digital LCDs, DLPs and plasma displays with resolutions up to 2560 x 1600.
  • Low-profile and flexible form factor
    Simplify IT administration and deployment throughout an enterprise. Regardless of desktop system (standard tower PC. workstation, small form factor system) or the display type (LCD, DLP, plasma) NVS 300 has the ability to fit into any existing installations without being disruptive.
  • High resolution display support
    Drive ultra high resolution panels using integrated display technologies, producing phenomenal photorealistic image quality from a range of display connectors. Support two simultaneous displays, including single-link DVI, DisplayPort, VGA or HDMI.
  • Dual DisplayPort (with audio)
    Support ultra-high-resolution panels (up to 2560 x 1600 at 30bpp) - enabling maximum range, resolution, refresh rate, and color depth designed to support the display technologies.
  • NVIDIA high definition video technology
    NVIDIA high definition video technology is the combination of high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content.
NVIDIA NVS 300 - graphics card - Quadro NVS 300 - 512 MB
Graphics card
Bus Type
PCI Express x16
Graphics Engine
NVIDIA Quadro NVS 300
512 MB DDR3
Memory Interface
64-bit
Max Resolution
2048 x 1536
Max Monitors Supported
2
Interfaces Details
DVI-I (dual link) (DMS-59) , 2 x VGA - with adapter , 2 x DisplayPort - with adapter
API Supported
DirectX 10.1, OpenGL 3.3
Workstation z200, z210, Z220, z400, Z420, z600, Z620, z800, Z820
Graphics card
Bus Type
PCI Express x16
Graphics Engine
Max Resolution
2048 x 1536
2
Interfaces Details
API Supported
Nvidia CUDA technology
Size
512 MB
DDR3 SDRAM
Bus Width
64-bit
Video Output
Supported Display Graphics
WUXGA (1920 x 1200), 2560x1600
Shipping Width
23.2 cm
Shipping Depth
18.4 cm
Shipping Height
5.8 cm
HP Workstation z200, z210, Z220, z400, Z420, z600, Z620, z800, Z820
