The next generation of HP InfiniBand Adapters for select HP ProLiant BLc, DL, ML, SL, and XL servers, Gen8 and Gen9 models. Based on Mellanox ConnectX-3 Pro technology for unprecedented scalability and fabric flexibility, they are all dual ported and can function as a dual ported InfiniBand card, a dual ported Ethernet card, or a mixed function card in rack servers. Combined with HP InfiniBand FDR edge switches, they deliver low-latency InfiniBand bandwidth, up to 56 Gb/s Fourteen Data Rate (FDR) or up to 40 Gb/s Quad Data Rate (QDR), for performance driven server and storage clustering applications in High Performance Computing (HPC) and enterprise data centers.
Next Generation InfiniBand/Ethernet Adapters for HP ProLiant Servers
Performance driven ConnectX-3 Pro architecture for InfiniBand bandwidth up to 56 Gb/s (FDR), Ethernet bandwidth up 40 Gb/s, and reduced application latency for either InfiniBand or Ethernet operation.PCI Express 3.0.Maximum effective network bandwidth through hardware-based traffic segregation (QoS) and congestion control.Low latency 10, 20, or 40 Gb/s Ethernet for FSI environments.Low power requirements, low cost per Gb/s bandwidth.
- QLogic IB 4X QDR PCI-e G2 Dual-port HCA - network adapter - PCIe 2.0 x8 - 2 ports
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ports Qty
- 2 ports
- Data Link Protocol
- InfiniBand
- Data Transfer Rate
- 40 Gbps
- System Requirements
- SUSE Linux Enterprise Server, Microsoft Windows, Red Hat Enterprise Linux
- 1-year warranty
- Designed For
- Apollo 4200 Gen9; ProLiant DL160se G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL380 Gen9, DL380p Gen8, DL385p Gen8, DL388p Gen8, DL580 G7, DL585 G7, ML350p Gen8, ML370 G6, SL160s G6, SL165s G7, SL165z G7, SL230s Gen8, SL250s Gen8, SL270s Gen8, XL170r Gen9, XL190r Gen9, XL230a Gen9; StoreEasy 1850
- Network adapter - 2 ports
- Form Factor
- Plug-in card
- Connectivity Technology
- Wired
- InfiniBand
- 40 Gbps
- InfiniBand QDR Link support
- Expansion Slots
- 2 x QSFP
- Compatible Slots
- 1 x PCI Express 2.0 x8
- OS Required
- Limited warranty - 1 year
- 0 °C
- 55 °C
- Designed For
- HPE Apollo 4200 Gen9 for Google , HPE ProLiant DL160 G6, DL160 G6 Special Server, DL160se G6, DL170h G6, DL180 G6, DL180 G6 Special Server, DL2x170h G6, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 Gen9 High Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL388p Gen8 Base, DL4x170h G6, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, ML350p Gen8, ML350p Gen8 Special Server, ML370 G6 Special Server, SL160s G6, SL160z G6, SL165s G7, SL165z G7, SL170z G6, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, SL2x170z G6, XL170r Gen9, XL190r Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G) , HPE StoreEasy 1850
