Is switch traffic and cabling a nightmare for you? The Moonshot 1500 Chassis comes with up to two HP Moonshot-180G Switch Modules each, so traffic is better managed, and units can be stacked for better resiliency. Each node is connected directly to the switch module via a single lane of high-speed fabric interconnect, providing a dedicated, low-latency 1 GbE bandwidth path to each node in the Moonshot System. These switches deliver high-density and low-power switching with Layer 2 and Layer 3 routing for ideal performance, delivered with the networking management features you expect and need. The Moonshot-180G Switch Module communicates with the external network through a Moonshot-4QSFP+ Uplink Module to deliver higher I/O performance with reduced oversubscription. The Moonshot-180G Switch Module provides sFlow and standard SNMP MIBs support for detailed switch statistics and telemetry. Instrumented for Quality of Service, license keys are not required for manageability features.
Performance with Efficiency
The HP Moonshot-180G Switch Module offers redundant, dual switches that provide traffic isolation and have the ability to stack for resiliency.Delivers high-density and low-power switching with Layer 2 and Layer 3 routing for ideal performance.When paired with Moonshot-4QSFP+ Uplink Module, the Moonshot-180G Switch Module delivers higher I/O performance with reduced oversubscription.Provides a dedicated, low-latency 1 GbE bandwidth path to each node in a Moonshot system. -
Manageability at Scale
Each HP Moonshot-180G Switch Module provides a 1 GbE out-of-band management port shared with iLO Chassis Manager for SSH or telnet sessions.Provides sFlow and standard SNMP MIBs support for detailed switch statistics and telemetry.Instrumented for Quality of Service (QoS).No license keys required to enable manageability features.
- HPE Moonshot 180G Switch Module - switch - 180 ports - Managed - plug-in module
- Switch - 180 ports - Managed - stackable
- Enclosure Type
- Plug-in module
- Subtype
- Gigabit Ethernet
- Ports
- 180 x 10/100/1000
- Performance
- Switching capacity: 660 Gbps , Throughput: 1.5 Mpps
- Jumbo Frame Support
- Routing Protocol
- OSPF, RIP, BGP, VRRP, ECMP
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, SSH, SSH-2, CLI
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, half duplex mode, full duplex mode, Weighted Fair Queuing (WFQ), Weighted Random Early Detection (WRED), sFlow, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Generic Attribute Registration Protocol (GARP), Type of Service (ToS)
- IEEE 802.3, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
- 14.1 cm x 37.6 cm x 3.7 cm
- 2.298 kg
- Enclosure Type
- Plug-in module
- Subtype
- Gigabit Ethernet
- Ports
- 180 x 10/100/1000
- Performance
- Routing Protocol
- Encryption Algorithm
- MD5, AES, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 2 GB SDRAM
- Status Indicators
- Link/activity
- 180 x Gigabit LAN , 4 x 40Gbit LAN uplink , 16 x 10Gbit LAN uplink
- UL 60950-1, EN 60950-1, RoHS, CSA C22.2 No. 60950-1
- 14.1 cm
- 37.6 cm
- 3.7 cm
- 2.298 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -30 °C
- Max Storage Temperature
- 60 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
