HPE HP ProLiant Moonshot-180G Switch Module Kit
Quicklinx: 9NZRWS00 Mfr#: 704642-B21
Type: Gigabit Ethernet
Ports: 180
Managed: Yes
£18,493.33 ex VAT
£22,191.99 inc VAT
Is switch traffic and cabling a nightmare for you? The Moonshot 1500 Chassis comes with up to two HP Moonshot-180G Switch Modules each, so traffic is better managed, and units can be stacked for better resiliency. Each node is connected directly to the switch module via a single lane of high-speed fabric interconnect, providing a dedicated, low-latency 1 GbE bandwidth path to each node in the Moonshot System. These switches deliver high-density and low-power switching with Layer 2 and Layer 3 routing for ideal performance, delivered with the networking management features you expect and need. The Moonshot-180G Switch Module communicates with the external network through a Moonshot-4QSFP+ Uplink Module to deliver higher I/O performance with reduced oversubscription. The Moonshot-180G Switch Module provides sFlow and standard SNMP MIBs support for detailed switch statistics and telemetry. Instrumented for Quality of Service, license keys are not required for manageability features.
  • Performance with Efficiency
    The HP Moonshot-180G Switch Module offers redundant, dual switches that provide traffic isolation and have the ability to stack for resiliency.Delivers high-density and low-power switching with Layer 2 and Layer 3 routing for ideal performance.When paired with Moonshot-4QSFP+ Uplink Module, the Moonshot-180G Switch Module delivers higher I/O performance with reduced oversubscription.Provides a dedicated, low-latency 1 GbE bandwidth path to each node in a Moonshot system.
  • Manageability at Scale
    Each HP Moonshot-180G Switch Module provides a 1 GbE out-of-band management port shared with iLO Chassis Manager for SSH or telnet sessions.Provides sFlow and standard SNMP MIBs support for detailed switch statistics and telemetry.Instrumented for Quality of Service (QoS).No license keys required to enable manageability features.
HPE Moonshot 180G Switch Module - switch - 180 ports - Managed - plug-in module
Switch - 180 ports - Managed - stackable
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
180 x 10/100/1000
Performance
Switching capacity: 660 Gbps , Throughput: 1.5 Mpps
Jumbo Frame Support
Routing Protocol
OSPF, RIP, BGP, VRRP, ECMP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, SSH, SSH-2, CLI
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, half duplex mode, full duplex mode, Weighted Fair Queuing (WFQ), Weighted Random Early Detection (WRED), sFlow, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Generic Attribute Registration Protocol (GARP), Type of Service (ToS)
IEEE 802.3, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
14.1 cm x 37.6 cm x 3.7 cm
2.298 kg
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
180 x 10/100/1000
Performance
Jumbo Frame Support
Routing Protocol
Encryption Algorithm
MD5, AES, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
2 GB SDRAM
Status Indicators
Link/activity
180 x Gigabit LAN , 4 x 40Gbit LAN uplink , 16 x 10Gbit LAN uplink
UL 60950-1, EN 60950-1, RoHS, CSA C22.2 No. 60950-1
14.1 cm
37.6 cm
3.7 cm
2.298 kg
10 °C
35 °C
10 - 90% (non-condensing)
Min Storage Temperature
-30 °C
Max Storage Temperature
60 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 180
Managed: Yes
Brand: HPE
Price Range Ex VAT: £1500+
