HPE HP ProLiant ML350e Gen8 E5-2420 1.9GHz 6-core Server
Quicklinx: 8BK9WS00 Mfr#: 686776-035
  • Xeon
  • Red Hat Enterprise Linux
HP ProLiant ML350e Gen8, a dual-socket 5U tower server, delivers essential performance with room to grow, while requiring low upfront investment. It is ideal for growing businesses running file/print, web messaging, and small vertical applications or databases.
  • Optimized for Price Performance
    Intel Xeon processor E5-2400 product family offers best price performance compute and memory; essential for everyday business needs.HP Smart Storage technology is designed to remove storage bottlenecks and turbo-charge data-intensive application performance to accelerate workloads.HP SmartMemory prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency.
  • Easy to Expand and Grow with Your Business
    Flexible design provides low-cost expansion capabilities as your business grows giving you the flexibility of adding a second processor, additional hard drive space, more memory, and more storage.HP SmartDrives offer more drive options including 24 SFF and 18 LFF drive cages giving you maximum flexibility for increased capacity for your local storage.Maximim expansion with support up to twelve (12) DDR3 1600 MHz DIMMs (192GB max), six PCI Express (PCIe) slots and 10 USB ports.
  • Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
    HP iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HP iLO, HP Agentless Management, HP Active Health System, HP Intelligent Provisioning, and HP Embedded Remote Support.HP Insight Control provides advanced management capabilities across the lifecycle of your HP ProLiant server infrastructure. HP iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while increasing Time-To-Resolution.HP Insight Online with HP Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HP SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HP Smart Update Manager (HP SUM), and Service Pack for ProLiant (SPP), and other products.
  • Lower Overall Cost of Ownership
    Less upfront investment while allowing for growth in the future.With embedded remote management technology, on-site server administration expenses are reduced and travel costs are eliminated.The high efficiency redundant power supplies and fans lower power consumption and reduce operational costs on a daily basis.First in industry to include 3D array of temperature sensors to help precisely control server fans to direct cooling and reduce unnecessary fan power, saving on cooling costs.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
HPE ProLiant ML350e Gen8 - tower - Xeon E5-2420 1.9 GHz - 4 GB
Server - tower
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon E5-2420 / 1.9 GHz (2.4 GHz) (6-core)
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
4 GB (installed) / 96 GB (max) DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
SATA (SATA 6Gb/s) - PCIe 2.0 (HP Dynamic Smart Array B120i)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200
GigE
21.8 cm x 74 cm x 46.2 cm
25.95 kg
Limited warranty - parts and labour - 1 year - on-site , Limited warranty - parts - 3 years
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 5U
Server Scalability
2-way
Front Accessible Bays Qty
2
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
4 GB / 96 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
12 (Total) / 11 (empty)
Unbuffered, low-voltage, HP SmartMemory
Configuration Features
1 x 4 GB
RAM Supported
PC3-12800 192 GB registered , PC3-12800 96 GB unbuffered - Advanced ECC , PC3-10600 96 GB - low voltage - unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated - PCIe 2.0
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express 2.0 x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Protocol
IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1s, IEEE 802.3az
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
2 (total) / 1 (free) x CPU , 12 (total) / 11 (free) x DIMM 240-pin , 1 (total) / 1 (free) x SD card , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode)
1 x serial , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HP iLO , 10 x USB 2.0 (4 front, 4 rear, 2 internal)
Administrator password, system password, power-on password, serial port I/O control
ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
Power supply
Nominal Voltage
Power Provided
460 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
21.8 cm
74 cm
46.2 cm
25.95 kg
10 °C
35 °C
10 - 90% (non-condensing)
Resources
