HPE HP ProLiant ML350 Gen9 Intel Xeon E5-2609v3 8GB
Quicklinx: 9XY0WS00 Mfr#: 776972-035
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Need to increase your business productivity and improve operations while balancing your employees' mobility, security and collaboration needs, all within your limited IT budget? HPE ProLiant ML350 Gen9 Server delivers a class-leading combination of performance, expandability, manageability, reliability and serviceability making it the choice for enterprise data centers, expanding SMBs and remote offices of larger businesses. ML350 Gen9 Server leverages the Intel Xeon E5-2600 v3 and v4 processors with up to 21% performance gain, plus the latest HPE DDR4 SmartMemory offering up to 23% performance increase. Additional support for 12 Gb/s SAS, embedded 4x1GbE NIC with a broad range of graphics and compute options. Manage your HPE ProLiant Server in any IT environments by automating the most essential server lifecycle management tasks: deploy, update, monitor, and maintain with ease. The ML350 Gen9 Server is ideal for enterprise IT infrastructure to mission critical applications.
  • Performance with Unmatched Capacity and Reliability
    The HPE ProLiant ML350 Gen9 Server supports up to (2) Intel Xeon E5-2600 v3 or v4 processors offering improved performance.HPE Smart Array Controllers are designed to increase 12 Gb/s performance, data availability and storage capacity while providing the flexibility in choice of solutions that are simple to manage.Up to (24) DIMM slots to support HPE DDR4 SmartMemory 2400MHz, helping to prevent data loss and downtime with enhanced error handling while improving workload performance and power efficiency.
  • Availability, Expandability and Serviceability - A Winning Combination
    The HPE ProLiant ML350 Gen9 Server offers expandability with greater capacity with (8) to (24) LFF, (8) to (48) SFF drive options and increased I/O expansion.Large expansion capacity with (9) PCIe expansion slots, (8) USB ports, 5U Rack conversion, and Power Supply options.Embedded 4x1Gbe and choice of HPE PCIe standup 1GbE, 10GbE or 25GbE Adapters provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Wider GPU support (4) to boost performance in graphic and VDI applications for financial services, education, scientific research, and medical imaging.Worldwide availability, service and support with a complete range of Foundation Care offerings from installation to extended support.
  • Agile Infrastructure Management for Essential Administration
    The HPE ProLiant ML350 Gen9 Server provides powerful converged management capabilities for the infrastructure lifecycle with embedded server management for provisioning, updating and diagnostic support with HPE iLO.Configure in Unified Extensible Firmware Interface (UEFI) boot mode to provision local and remote servers with HPE iLO with Intelligent Provisioning and Scripting Toolkits.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Optimize firmware and driver updates and reduce downtime with Smart Update Solution, consisting of Smart Update Manager (SUM) and Service Pack for ProLiant (SPP).
  • Energy Efficiency by Design
    The HPE ProLiant ML350 Gen9 Server offers ENERGY STAR qualified server configurations illustrate the HPE continued commitment to helping customers conserve energy and save money.Next generation high efficiency redundant HPE Flexible Slot Power Supplies provide up to 96% efficiency (Titanium).Improved ambient temperature standard with ASHRAE A3 and A4 helps you reduce cooling costs.
HPE ProLiant ML350 Gen9 - tower - Xeon E5-2609V3 1.9 GHz - 8 GB - no HDD
Server - tower - administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon E5-2609V3 / 1.9 GHz (6-core)
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
8 GB (installed) / 384 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (Smart Array P440ar with 2GB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200
GigE
Power Redundancy
Optional
21.9 cm x 76.9 cm x 46.4 cm
30 kg
Manufacturer Selling Program
HP Top Value
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 5U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
1.9 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 384 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
24 (Total)
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
RAM Supported
PC4-17000 - 768 GB Load-Reduced , PC4-17000 - 384 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Integrated
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 8 (total) / 6 (free) x hot-swap 2.5" SFF
Slots
24 DIMM 288-pin , 2 (total) / 1 (free) x CPU , 4 (total) / 4 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x microSD Card (internal)
1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 2 x USB 3.0 , 4 x USB 2.0 (2 front, 2 rear)
Administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
HP Top Value
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Citrix XenServer, Canonical Ubuntu
21.9 cm
76.9 cm
46.4 cm
30 kg
10 °C
35 °C
8 - 90% (non-condensing)
9XY0 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.60
