Product
Brand
HPE HP ProLiant ML150 Gen9 Intel Xeon E5-2620v3 8GB
Quicklinx: BGLPWS00 Mfr#: 780850-035
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Are you searching for a tower server to meet the requirements of your small to medium-sized growing business? The HPE ProLiant ML150 Gen9 Server is a tower server that delivers exceptional value for a business with a limited budget with a 24-inch chassis depth. Providing dual processor sockets, it provides essential performance with the Intel Xeon E5-2600 v4 processors. Built-in innovations that simplify server deployment and management, your business can continually reap these benefits on a daily basis, with expansion options that enable you to expand as needed, delivering increased business value. The HPE ProLiant ML150 Gen9 Server provides efficiency and productivity for both the small to medium organization that is growing.
HPE ProLiant ML150 Gen9 - tower - Xeon E5-2620V3 2.4 GHz - 8 GB - 0 GB
Server - tower
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon E5-2620V3 / 2.4 GHz (3.2 GHz) (6-core)
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
8 GB (installed) / 256 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HP H240 Smart Host Bus Adapter)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-RW
GigE
20 cm x 62 cm x 43.26 cm
16.9 kg
3 years warranty - on-site (1st year only)
Server
Product Form Factor
Tower - 5U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C612
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 256 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
Configuration Features
1 x 8 GB
RAM Supported
PC4-17000 - 256 GB Load-Reduced , PC4-17000 - 256 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5
Optical Storage
DVD-RW - SATA
Monitor
Monitor Type
None.
Integrated
Interface (Bus) Type
PCI Express x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
16 (total) / 15 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 3 PCIe 3.0 x8 - half-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x microSD Card (internal)
1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HP iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 3 x USB 2.0 (2 rear, 1 internal)
Administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
Power supply
Nominal Voltage
Power Provided
550 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Canonical Ubuntu
Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site
20 cm
62 cm
43.26 cm
16.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
