The HP Moonshot System with ProLiant m700 Server Cartridges offers up to 44% lower TCO, while dramatically improving security and compliance by centralizing desktops, data, and applications in the data center.* With four AMD Opteron X2150 APUs per cartridge, the ProLiant m700 Server Cartridge delivers up to 720 processor cores/chassis along with fully-integrated graphics processing to enhance productivity from any device. Up to 45 server cartridges fit in one converged Moonshot System for 1,800 servers/rack, so you spend less on racks, switches and cables.
Hosted Desktop Infrastructure Workloads
The HP ConvergedSystem 100 for Hosted Desktops is built on the Moonshot System with 45 ProLiant m700 Server Cartridges cost-effectively delivering 180 desktops for Citrix XenDesktop environments.Each cartridge has four AMD Opteron X2150 APUs with integrated graphics processing for 6x faster graphics frames per second.Moonshot System density means that you can cost-effectively have 1,800 servers/rack so you spend less on space, power and cooling.Up to 64 MB of storage per server, enabling both persistent and non-persistent hosted desktop deployments.
- HPE ProLiant m700 - cartridge - Opteron X2150 1.5 GHz - 32 GB - no HDD
- Server - cartridge
- Server Scalability
- 4-way
- Processor
- 4 x AMD Opteron X2150 / 1.5 GHz (Quad-Core)
- Cache Memory
- 8 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 32 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 8000
- Networking
- GigE
- 16.71 cm x 18.37 cm x 1.98 cm
- Pricing Type
- CTO
- Limited warranty - parts - 3 years
- Server
- Product Form Factor
- Cartridge
- 4-way
Processor / Chipset
- CPU
- AMD Opteron X2150
- Clock Speed
- 1.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 4
- Max CPU Qty
- 4
Cache Memory
- Installed Size
- L2 Cache - 8 MB
- 2 MB
RAM
- Installed Size
- 32 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 4 (Total) / 0 (empty)
- Configuration Features
- 4 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- PXE support
- Slots
- 4 (total) / 0 (free) x SO-DIMM 204-pin , 4 (total) / 4 (free) x Mezzanine card
- ACPI 2.0, WEEE, ACPI 3.0a
- Pricing Type
- CTO
Operating System / Software
- OS Certified
- Microsoft Windows 7 Enterprise SP1, Windows 8.1 64-bit Edition, Red Hat Enterprise Linux 6.5, Red Hat Enterprise Linux 7
- 16.71 cm
- 18.37 cm
- 1.98 cm
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
