HPE ProLiant Gen8 Entry Intel G1610T Celeron 4GB RAM MicroServer
Quicklinx: BM14WS00 Mfr#: 819185-421
  • Celeron
  • Red Hat Enterprise Linux
The HP ProLiant MicroServer Gen8 is a small, quiet, and stylishly designed server that is ideal as a first server solution for small businesses. With a form factor that is easy to use and service, it helps small businesses drive down their expenses while improving productivity, efficiency, and security. HP ProLiant MicroServer Gen8 comes with HP iLO4, providing access to innovations like Intelligent Provisioning for quick and simple installation and setup.
  • Instant out-of-box server set up and deployment
  • Ideal first server for a small or home office scenario using Windows Server 2012 Foundation software
  • Perfect home media server using Windows 7 Home Premium
  • Tool-less access to hard drives, memory, and PCI slots for simple installation or upgrade
  • Improved serviceability with features such as icon-based status display and system health status LEDs
  • Two up-front USB ports allow for easy deployment
  • New iLO Essentials license provides ability to connect media from your client device to your server and receive email alerts regarding server events
  • Small, quiet, energy efficient, and can be placed anywhere
  • Stylish blue LED light bar for at-a-glance system health status
  • Stackable managed switch creates clean, elegant look for networking and compute
  • Compatible with HP PS1810 Switch - unique chassis design for the 8-port managed switch that enables physical stacking
Optical drive not included
Please see Resources tab to obtain your Cashback claim form!
  • Simplified IT Management with Built-in Gen8 Technologies
    HPE ProLiant MicroServer Gen8 comes with HPE iLO4, providing access to innovations like Intelligent Provisioning for quick and simple installation and setup.Instant out-of-box server set up and deployment.Embedded remote management technology reduces on-site server administration and travel expenses.Continuous, proactive health monitoring ensures faster and more accurate problem resolution.
  • Worry-free Serviceability Maximizing Uptime and Productivity
    HPE ProLiant MicroServer Gen8 is available with tool-less access to hard drives, memory, and PCI slots for simple installation or upgrade.Two up-front USB ports allow for easy deployment.HPE Integrated Lights-Out (iLO) Essentials license provides ability to connect media from your client device to your server and receive email alerts regarding server events.
  • Unique Server Design ideal for Small Offices
    HPE ProLiant MicroServer Gen8 allows you to personalize your HPE ProLiant MicroServer with the front bezel faceplate kit.Small, quiet, energy efficient, and can be placed anywhere.Stylish blue LED light bar for at-a-glance system health status.Stackable wireless router and managed switch creates clean, elegant look for networking and compute.
  • Seamless Network Connectivity Extends Benefits of Converged Infrastructure
    HPE ProLiant MicroServer Gen8 supports the HPE PS110 Wireless VPN Router which provide an access point for wireless connectivity in office as well as VPN technology for secure remote access.Compatible with the HPE PS1810 Switch Series. Unique chassis design for the 8-port managed switch and router that enables physical stacking. A 24-port switch is available for larger office environments.User-friendly interface on the HPE PS1810 Switch Series allows for consolidated view of servers and switches in the network so workloads can be prioritized.Link aggregation allows for faster file transfers and greater data availability.
HPE ProLiant MicroServer Gen8 Entry - ultra micro tower - Celeron G1610T 2.3 GHz - 4 GB - no HDD
Server - ultra micro tower - Setup Password
Region: Europe
Server Scalability
1-way
1 x Intel Celeron G1610T / 2.3 GHz (Dual-Core)
Cache Memory
2 MB L3 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s) - PCIe 2.0 (HP Dynamic Smart Array B120i)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
1GbE
23 cm x 24.5 cm x 23.24 cm
6.8 kg
Limited warranty - parts - 1 year - response time: next business day
Server
Product Form Factor
Ultra micro tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C204
Cache Memory
Installed Size
L3 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, HP SmartMemory
Configuration Features
1 x 4 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - PCIe 2.0
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
5
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Interfaces
VGA
Interface (Bus) Type
PCI Express x1
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC332i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x microSD Card (internal)
1 x VGA , 5 x USB 2.0 (2 front, 2 rear, 1 internal) , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 2 x USB 3.0
Setup Password
ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438, GB 9254
Power supply
Power Provided
200 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
23 cm
24.5 cm
23.24 cm
6.8 kg
10 °C
35 °C
10 - 90% (non-condensing)
BM14 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
BM14 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £18.89
Resources
The following resources are available for the HPE ProLiant Gen8 Entry Intel G1610T Celeron 4GB RAM MicroServer
